[MPICH] mpich2: smpd phrase missing? - did you specify -smpdfile for smpd&mpixec ?
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Jan 21 16:21:26 CST 2008
 Have you specified the "-smpdfile a_copy_of_my_smpd_file" option for smpd &
mpiexec ? The MPICH2 user's guide
(http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=d
ocs) contains information about the different options available with
mpiexec/smpd.
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Stefan Becuwe
Sent: Monday, January 21, 2008 4:01 PM
To: Jayesh Krishna
Cc: mpich-discuss at mcs.anl.gov
Subject: RE: [MPICH] mpich2: smpd phrase missing? - don't share config file
across PMs
>  Are you sharing the smpd configuration file (by default ~/.smpd)
> across multiple smpd daemons ? Each smpd daemon should have its own
> configuration file (Only smpd root daemons modify the configuration
> file. Currently there is no locking mechanism implemented on unix
> systems to prevent multiple smpd root daemons from modifying the config
file at the same time.).
Thanks for your advice.  Looking into "mpiexec -help2", I've tried the
options "-smpdfile a_copy_of_my_smpd_file" and "-noprompt" (separately) ...
without success.  I still get:
"Please specify an authentication passphrase for this smpd: Would you like
to save this passphrase in '...'?
I guess I must be overlooking something...
Best regards
Stefan
