[MPICH] Confused about compiling/using mpich2
    Rajeev Thakur
    thakur at mcs.anl.gov
    Tue Jan  8 15:08:50 CST 2008
If your code is compiled with MPICH2, it shouldn't run with MPICH-1's
mpirun. Make sure that all your code is compiled with the compile scripts
from MPICH2 and there are no mpif.h files from MPICH-1 in any of your source
directories.
Rajeev
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Gaetano Bellanca
Sent: Monday, January 07, 2008 12:16 PM
Subject: Re: [MPICH] Confused about compiling/using mpich2
Dear Darius,
thank you for your answer. But I'm not sure this is the problem. In fact,
MPI_Finalize is far from the point where the code is stopped by this error,
and there are a lot of other routines before the end of the program.
Moreover my code works works with MPICH1.2.7p1 (without this problem) and
also with MPICH2 (if i run it with mpirun of the mpich1.2.7p1 instead of
mpiexec or mpirun of MPICH2).
I'm rather confused about that .... maybe I'm doing something wrong in using
mpiexec.
Regards.
Gaetano
  _____
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44100 - Ferrara - ITALY
Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
mailto:gaetano.bellanca at unife.it
  _____
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080108/23b19323/attachment.htm>
