[MPICH] MPICH2 1.0.6 inder Windows without DOMAIN
    Christoph Lupprich
    christoph at lupprich.info
    Sat Jan  5 11:25:10 CST 2008
There's a pdf called something like "MPICH2 for Windows developers" on
the official MPICH2 website.
Do you have the same username/password combination on the two machines
(that makes life easier, however, there are ways around this).
-Christoph
On Jan 5, 2008, at 17:53 PM, madfran wrote:
> Hi,...
> No succes putting the IP addresses instead the computer name.
> In my opinion it is a problem with the user but I am not sure.
> The documentation for windows it is not clear.
> I found something in http://202.117.122.28/newindex/huchongwei/
> MPI.pdf but it
> is not ufficial documention and say things diferent than the
> information
> found in README.winbin.rtf
> Where can I find ufficial documentation about MPICH2 under windows ?
> On Fri, 4 Jan 2008 00:34:41 +0100, Christoph Lupprich wrote
>> You can try IP addresses or put the IP address along with the
>> hostname  into Windows' host file (in
>> C:\Windows\system32\drivers\etc).
>> Kind regards,
>> Christoph
>> On Jan 3, 2008, at 22:08 PM, madfran wrote:
>>> Hi,...
>>> I tring to use MPICH2 under windows without DOMAIN.
>>> To begin I use only two computers,
>>> - master with XP (a laptop dual core)
>>> - slave with Windows 2000 (a fix with a pentium 1,2)
>>> The MPICH2 is installed in the laptop.
>>> This laptop work under a DOMAIN in others situation, but not in this
>>> moment.
>>> The fix computer work alone with a Workgroup. The name of this
>>> computer is
>>> HoneyPot
>>> When a try "mpiexec -channel auto -machinefile maquinas.txt -pwd
>>> file
>>> usuarios.txt -n 4 pci.exe"
>>> I receive the folowwing message.
>>> "Aborting: unable to connect to HoneyPot"
>>> I need some detailled instructions for windows networks.
>>> Where can I find it?
