[MPICH] MPICH2 1.0.6 inder Windows without DOMAIN
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Jan  7 10:30:21 CST 2008
  The official documentation for MPICH2 on windows is available at
http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=do
cs .
  Please try the suggestions provided below and let us know the results
(Substitute the CAPITALIZED words in the commands below with the appropriate
names/values),
1) Make sure that any firewalls on both the machines are turned off and that
the machines are reachable from one another (ping).
2) Check the status of the process managers on both machines from the
machine where you launch your job,
   2.1) smpd -status
   2.2) smpd -status REMOTEHOSTIPADDRESS
3) Register the usernames and passwords on both the machines (mpiexec
-register ...)
4) Validate the username/password on both the machines from the machine
   4.1) mpiexec -validate -user USERNAME
   4.2) mpiexec -validate -user USERNAME -host HOSTNAME
Jayesh
-----Original Message-----
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of madfran
Sent: Saturday, January 05, 2008 10:53 AM
Subject: Re: [MPICH] MPICH2 1.0.6 inder Windows without DOMAIN
Hi,...
No succes putting the IP addresses instead the computer name.
In my opinion it is a problem with the user but I am not sure.
The documentation for windows it is not clear.
I found something in http://202.117.122.28/newindex/huchongwei/MPI.pdf but
it is not ufficial documention and say things diferent than the information
found in README.winbin.rtf
Where can I find ufficial documentation about MPICH2 under windows ?
On Fri, 4 Jan 2008 00:34:41 +0100, Christoph Lupprich wrote
> You can try IP addresses or put the IP address along with the hostname
> into Windows' host file (in C:\Windows\system32\drivers\etc).
> Kind regards,
> Christoph
> On Jan 3, 2008, at 22:08 PM, madfran wrote:
> > Hi,...
> > I tring to use MPICH2 under windows without DOMAIN.
> > To begin I use only two computers,
> > - master with XP (a laptop dual core)
> > - slave with Windows 2000 (a fix with a pentium 1,2)
> > The MPICH2 is installed in the laptop.
> > This laptop work under a DOMAIN in others situation, but not in this
> > moment.
> > The fix computer work alone with a Workgroup. The name of this
> > computer is HoneyPot
> > When a try "mpiexec -channel auto -machinefile maquinas.txt -pwd
> > file usuarios.txt -n 4 pci.exe"
> > I receive the folowwing message.
> > "Aborting: unable to connect to HoneyPot"
> > I need some detailled instructions for windows networks.
> > Where can I find it?
