[MPICH] MPICH2 1.0.6 inder Windows without DOMAIN
    madfran
    madfran at set-ezine.org
    Sat Jan  5 10:53:23 CST 2008
Hi,...
No succes putting the IP addresses instead the computer name.
In my opinion it is a problem with the user but I am not sure.
The documentation for windows it is not clear.
I found something in http://202.117.122.28/newindex/huchongwei/MPI.pdf but it
is not ufficial documention and say things diferent than the information
found in README.winbin.rtf
Where can I find ufficial documentation about MPICH2 under windows ?
On Fri, 4 Jan 2008 00:34:41 +0100, Christoph Lupprich wrote
> You can try IP addresses or put the IP address along with the
> hostname  into Windows' host file (in
> C:\Windows\system32\drivers\etc).
> Kind regards,
> Christoph
> On Jan 3, 2008, at 22:08 PM, madfran wrote:
> > Hi,...
> > I tring to use MPICH2 under windows without DOMAIN.
> > To begin I use only two computers,
> > - master with XP (a laptop dual core)
> > - slave with Windows 2000 (a fix with a pentium 1,2)
> > The MPICH2 is installed in the laptop.
> > This laptop work under a DOMAIN in others situation, but not in this
> > moment.
> > The fix computer work alone with a Workgroup. The name of this
> > computer is
> > HoneyPot
> > When a try "mpiexec -channel auto -machinefile maquinas.txt -pwd file
> > usuarios.txt -n 4 pci.exe"
> > I receive the folowwing message.
> > "Aborting: unable to connect to HoneyPot"
> > I need some detailled instructions for windows networks.
> > Where can I find it?
