[MPICH] build mpich2 with Myrinet GM
Darius Buntinas
buntinas at mcs.anl.gov
Tue Feb 26 10:24:11 CST 2008
On 02/26/2008 10:08 AM, Wei-keng Liao wrote:
> I have a few questions on build mpich2-1.0.6p1 with Myrinet GM library.
> On my target machine, the GM library (include, lib, bin, etc.) is in
> /opt/gm. According to MPICH README, I used the 2 options below when
> configuring:
> --with-device=ch3:nemesis:gm and --with-gm=/opt/gm
> I can see both libgm.a and libgm.so are in /opt/gm/lib.
> Q1: Do I need other configure options or setting environment variables
> (in addition to CC, FC, CXX, F90)? Should I set LDFLAGS
> to "-L/opt/gm/lib -lgm" ?
Nope, the --with-gm=/opt/gm should take care of all of that for you.
> Q2: Since nemesis does not support MPI dynamic process routines yet and I
> need those routines, can I use --with-device=ch3:sock:gm instead?
No, only nemesis supports gm.
> Q3: Do I need anything else (source codes, library) from Myrinet to build
> mpich? Or the /opt/gm is good enough?
All you need is libgm.a and gm.h.
> Q4: Once the mpich is built, is there a way to verify that GM is actually
> used?
Well, you should see a performance improvement over using sockets. Run
a ping-pong test; you should see latencies around 10us or less.
-d
