[MPICH] Problem setting up MPICH between a 32 bit INTEL and a 32 bit AMD machine
    Dave Goodell
    goodell at mcs.anl.gov
    Fri Feb 15 14:22:08 CST 2008
What evidence do you have that the two machines are able to see each
other on the network?  Can you ping from one to the other (and vice
versa)?  What is the output of the 'route' command on each of the hosts?
-Dave
On Feb 14, 2008, at 10:30 PM, Krishna Chaitanya wrote:
> Hi,
>           Turns out that the settings in the /etc/hosts file on the
> AMD machine was incorrect. So, mpdcheck -v -f mpd.hosts gives this :
> AMD machine : ( outwit )
> kc at outwit:~$ mpdcheck -v -f mpd.hosts
> obtaining hostname via gethostname and getfqdn
> gethostname gives  outwit
> getfqdn gives  outwit.nitk.ac.in
> checking out unqualified hostname; make sure is not "localhost", etc.
> checking out qualified hostname; make sure is not "localhost", etc.
> obtain IP addrs via qualified and unqualified hostnames;  make sure
> other than 127.0.0.1
> gethostbyname_ex:  ('outwit.nitk.ac.in', ['outwit'], ['172.16.54.54'])
> checking that IP addrs resolve to same host
> now do some gethostbyaddr and gethostbyname_ex for machines in
> hosts file
> checking gethostbyXXX for unqualified zeus
> gethostbyname_ex:  ('zeus', [], ['172.16.54.71'])
> checking gethostbyXXX for qualified zeus
> INTEL machine ( zeus )
> kris.c1986 at zeus ~]$ mpdcheck -v -f mpd.hosts
> gethostname gives  zeus
> getfqdn gives  zeus.nitk.ac.in
> gethostbyname_ex:  ('zeus.nitk.ac.in', ['zeus'], ['172.16.54.71'])
> hosts file
> checking gethostbyXXX for unqualified outwit
> gethostbyname_ex:  ('outwit', [], ['172.16.54.54'])
> checking gethostbyXXX for qualified outwit
>                Seems to be ok. But I still get this error when I
> try mpdcheck -c on the AMD comp :
> kc at outwit:~$ mpdcheck -c zeus 33737
> Traceback (most recent call last):
>   File "/home/kc/mpich-install/bin/mpdcheck", line 103, in <module>
>     sock.connect((argv[argidx+1],int(argv[argidx+2])))  # note
> double parens
>   File "<string>", line 1, in connect
> socket.error: (113, 'No route to host')
>            The two machines are able to see each other on the
> network. Cant exaplain why it complains that there is "No route to
> host"
> Krishna Chaitanya K
> On Thu, Feb 14, 2008 at 2:50 PM, Rajeev Thakur <thakur at mcs.anl.gov>
> wrote:
> The second test times out perhaps indicates that there might be a
> firewall on the AMD machine. See the section A.3 of the
> installation guide.
> Rajeev
> From: Krishna Chaitanya [mailto:kris.c1986 at gmail.com]
> Sent: Thursday, February 14, 2008 11:41 AM
> To: Rajeev Thakur
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] Problem setting up MPICH between a 32 bit
> So, what is the error trying to convey? Googling for it, gave this.
> I have flushed the IPtables on both the machines and the firewalls
> are de-activated. Could you please elaborate on what kind of
> settings I need to look into?
> Thanks,
> Krishna Chaitanya K
> On Thu, Feb 14, 2008 at 10:58 PM, Rajeev Thakur
> <thakur at mcs.anl.gov> wrote:
> It should be possible. mpdcheck is a tool to diagnose whether the
> network configuration settings on the machines are ok or not, and
> whether a process on one machine can talk to a process on the
> other. It looks like the settings need to be fixed in some way.
> Rajeev
> From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-
> discuss at mcs.anl.gov] On Behalf Of Krishna Chaitanya
> Sent: Thursday, February 14, 2008 10:26 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Problem setting up MPICH between a 32 bit INTEL
> Hi,
>         In one of the previous posts, you had replied back saying
> MPICH cannot be put to use between a 32 bit INTEL machine and a 64
> bit AMD machine. Is it possible to do so between an INTEL and an
> AMD machine, both of them being 32 bit processors?
>         Anyway, on trying mpdcheck -f mpd.hosts on the 32 bit AMD,
> I am getting the following error :
>    ipaddr via uqn (208.67.216.130) does not match via fqn
> (208.69.32.130)
>         And if I try the mpdcheck -s on the AMD node and mpdcheck -
> c on the INTEL node, the client times out. The test message gets
> delivered with the client and server swapped.
> Thanks,
> Krishna Chaitanya K
> In the middle of difficulty, lies opportunity
