[MPICH] Problem setting up MPICH between a 32 bit INTEL and a 32 bit AMD machine
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Mon Feb 18 22:35:53 CST 2008
Sorry for the delay.
>Can you ping from one to the other
          Yes, I was able to ssh into the other machine and try mpdcheck and
the rest. Will try to figure out what the problem is.
In the mean-time, I have been trying to understand the progress engine by
tracing a standard blocking mode send/recv program, on one machine. ( by
using mpdboot -n 1). What exactly are the .i files in the directory
/mpid/common/sock/poll for?
I noticed that a function like "MPIDU_Sock_post_readv" is at :
1) src/mpid/common/sock/iocp/sock.c, which includes functions like
"WSARecv",which is a function to receive data from a socket in windows. ( I
am working on a linux platform)
2)/mpich-src/src/mpid/common/sock/poll/sock_post.i.
             Interestingly, I am not able to navigate through the macros and
functions in this file,by using tags (Why? ) . So, I can only see that we
are playing around with pointers to update the pollinfo structure. Where is
this structure defined? The .i file does not include any .h file. I tried
"grep" on the main dir to locate the definition, it didnt return anything
useful.
             Can someone point me to a wiki article or any documentation
that gives some info on the .i files?
Krishna Chaitanya K
On Feb 15, 2008 3:22 PM, Dave Goodell <goodell at mcs.anl.gov> wrote:
> What evidence do you have that the two machines are able to see each
> other on the network?  Can you ping from one to the other (and vice
> versa)?  What is the output of the 'route' command on each of the hosts?
> -Dave
> On Feb 14, 2008, at 10:30 PM, Krishna Chaitanya wrote:
> > Hi,
> >           Turns out that the settings in the /etc/hosts file on the
> > AMD machine was incorrect. So, mpdcheck -v -f mpd.hosts gives this :
> > AMD machine : ( outwit )
> > kc at outwit:~$ mpdcheck -v -f mpd.hosts
> > obtaining hostname via gethostname and getfqdn
> > gethostname gives  outwit
> > getfqdn gives  outwit.nitk.ac.in
> > checking out unqualified hostname; make sure is not "localhost", etc.
> > checking out qualified hostname; make sure is not "localhost", etc.
> > obtain IP addrs via qualified and unqualified hostnames;  make sure
> > other than 127.0.0.1
> > gethostbyname_ex:  ('outwit.nitk.ac.in', ['outwit'], ['172.16.54.54'])
> > checking that IP addrs resolve to same host
> > now do some gethostbyaddr and gethostbyname_ex for machines in
> > hosts file
> > checking gethostbyXXX for unqualified zeus
> > gethostbyname_ex:  ('zeus', [], ['172.16.54.71'])
> > checking gethostbyXXX for qualified zeus
> > INTEL machine ( zeus )
> > kris.c1986 at zeus ~]$ mpdcheck -v -f mpd.hosts
> > gethostname gives  zeus
> > getfqdn gives  zeus.nitk.ac.in
> > gethostbyname_ex:  ('zeus.nitk.ac.in', ['zeus'], ['172.16.54.71'])
> > hosts file
> > checking gethostbyXXX for unqualified outwit
> > gethostbyname_ex:  ('outwit', [], ['172.16.54.54'])
> > checking gethostbyXXX for qualified outwit
> >                Seems to be ok. But I still get this error when I
> > try mpdcheck -c on the AMD comp :
> > kc at outwit:~$ mpdcheck -c zeus 33737
> > Traceback (most recent call last):
> >   File "/home/kc/mpich-install/bin/mpdcheck", line 103, in <module>
> >     sock.connect((argv[argidx+1],int(argv[argidx+2])))  # note
> > double parens
> >   File "<string>", line 1, in connect
> > socket.error: (113, 'No route to host')
> >            The two machines are able to see each other on the
> > network. Cant exaplain why it complains that there is "No route to
> > host"
> > Krishna Chaitanya K
> > On Thu, Feb 14, 2008 at 2:50 PM, Rajeev Thakur <thakur at mcs.anl.gov>
> > wrote:
> > The second test times out perhaps indicates that there might be a
> > firewall on the AMD machine. See the section A.3 of the
> > installation guide.
> > Rajeev
> > From: Krishna Chaitanya [mailto:kris.c1986 at gmail.com]
> > Sent: Thursday, February 14, 2008 11:41 AM
> > To: Rajeev Thakur
> > Cc: mpich-discuss at mcs.anl.gov
> > Subject: Re: [MPICH] Problem setting up MPICH between a 32 bit
> > So, what is the error trying to convey? Googling for it, gave this.
> > I have flushed the IPtables on both the machines and the firewalls
> > are de-activated. Could you please elaborate on what kind of
> > settings I need to look into?
> > Thanks,
> > Krishna Chaitanya K
> > On Thu, Feb 14, 2008 at 10:58 PM, Rajeev Thakur
> > <thakur at mcs.anl.gov> wrote:
> > It should be possible. mpdcheck is a tool to diagnose whether the
> > network configuration settings on the machines are ok or not, and
> > whether a process on one machine can talk to a process on the
> > other. It looks like the settings need to be fixed in some way.
> > Rajeev
> > From: owner-mpich-discuss at mcs.anl.gov [mailto:owner-mpich-
> > discuss at mcs.anl.gov] On Behalf Of Krishna Chaitanya
> > Sent: Thursday, February 14, 2008 10:26 AM
> > To: mpich-discuss at mcs.anl.gov
> > Subject: [MPICH] Problem setting up MPICH between a 32 bit INTEL
> > Hi,
> >         In one of the previous posts, you had replied back saying
> > MPICH cannot be put to use between a 32 bit INTEL machine and a 64
> > bit AMD machine. Is it possible to do so between an INTEL and an
> > AMD machine, both of them being 32 bit processors?
> >         Anyway, on trying mpdcheck -f mpd.hosts on the 32 bit AMD,
> > I am getting the following error :
> >    ipaddr via uqn (208.67.216.130) does not match via fqn
> > (208.69.32.130)
> >         And if I try the mpdcheck -s on the AMD node and mpdcheck -
> > c on the INTEL node, the client times out. The test message gets
> > delivered with the client and server swapped.
> > Thanks,
> > Krishna Chaitanya K
> > In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080218/9f734494/attachment.htm>
