[MPICH] Problem setting up MPICH between a 32 bit INTEL and a 32 bit AMD machine
Rajeev Thakur thakur at mcs.anl.gov
Thu Feb 14 11:28:08 CST 2008
It should be possible. mpdcheck is a tool to diagnose whether the network
configuration settings on the machines are ok or not, and whether a process
on one machine can talk to a process on the other. It looks like the
settings need to be fixed in some way.
Rajeev
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Krishna Chaitanya
Sent: Thursday, February 14, 2008 10:26 AM
Subject: [MPICH] Problem setting up MPICH between a 32 bit INTEL and a 32
bit AMD machine
        In one of the previous posts, you had replied back saying MPICH
cannot be put to use between a 32 bit INTEL machine and a 64 bit AMD
machine. Is it possible to do so between an INTEL and an AMD machine, both
of them being 32 bit processors?
        Anyway, on trying mpdcheck -f mpd.hosts on the 32 bit AMD, I am
getting the following error :
   ipaddr via uqn (208.67.216.130) does not match via fqn (208.69.32.130)
        And if I try the mpdcheck -s on the AMD node and mpdcheck -c on the
INTEL node, the client times out. The test message gets delivered with the
client and server swapped.
Krishna Chaitanya K
In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080214/facb7b79/attachment.htm>
