[MPICH] Problem setting up MPICH between a 32 bit INTEL and a 32 bit AMD machine
    Krishna Chaitanya
    kris.c1986 at gmail.com
    Thu Feb 14 11:40:49 CST 2008
So, what is the error trying to convey? Googling for it, gave
this.<http://tell11.utsi.edu/mpich2-1.0.6p1/bin/mpdcheck>
I have flushed the IPtables on both the machines and the firewalls are
de-activated. Could you please elaborate on what kind of settings I need to
look into?
Krishna Chaitanya K
On Thu, Feb 14, 2008 at 10:58 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
>  It should be possible. mpdcheck is a tool to diagnose whether the network
> configuration settings on the machines are ok or not, and whether a process
> on one machine can talk to a process on the other. It looks like the
> settings need to be fixed in some way.
> Rajeev
> *From:* owner-mpich-discuss at mcs.anl.gov [mailto:
> owner-mpich-discuss at mcs.anl.gov] *On Behalf Of *Krishna Chaitanya
> *Sent:* Thursday, February 14, 2008 10:26 AM
> *To:* mpich-discuss at mcs.anl.gov
> *Subject:* [MPICH] Problem setting up MPICH between a 32 bit INTEL and a
> 32 bit AMD machine
> Hi,
>         In one of the previous posts, you had replied back saying MPICH
> cannot be put to use between a 32 bit INTEL machine and a 64 bit AMD
> machine. Is it possible to do so between an INTEL and an AMD machine, both
> of them being 32 bit processors?
>         Anyway, on trying mpdcheck -f mpd.hosts on the 32 bit AMD, I am
> getting the following error :
>    ipaddr via uqn (208.67.216.130) does not match via fqn (208.69.32.130)
>         And if I try the mpdcheck -s on the AMD node and mpdcheck -c on
> the INTEL node, the client times out. The test message gets delivered with
> the client and server swapped.
> Thanks,
> Krishna Chaitanya K
> In the middle of difficulty, lies opportunity
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20080214/04056ead/attachment.htm>
