[MPICH] MPICH2 with MS Vista
    Brian Andrus
    toomuchit at gmail.com
    Mon Feb  4 13:34:50 CST 2008
Jayesh,
No luck. I uninstalled MPICH2, ensured the entry for it was not listed
in the manage computer->services section and rebooted. I ran the
installer, used the default passphrase and rebooted after it said it was
successfully installed.
Then I opened a command window and ran:
    "\Program Files\MPICH2\bin\mpiexec.exe" -n 1 dir
It asks for a passphrase and I get an error:
Please specify an authentication passphrase for smpd:
Unable to connect to 'Brian-PC:8676',
sock error: generic socket failure, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to Brian-PC on port
8676, exhausted all endpoints (errno -1)
MPIDU_Sock_post_connect(1275): unable to connect to Brian-PC on port
8676, No connection could be made because the target machine actively
refused it. (errno 10061)
I look at the manage computer->services and MPICH2 is not listed. It
does not install the smpd service successfully, I think. The only way I
have been able to see it installed is when I open a command window using
administrator privileges and running:
    "\Program Files\MPICH2\bin\smpd.exe" -install
I tried starting the service:
C:\Users\Brian>"\Program Files\MPICH2\bin\smpd.exe" -start
OpenSCManager failed:
Access is denied. (error 5)
So I tried starting it from an admin console:
C:\Windows\system32>"\Program Files\MPICH2\bin\smpd.exe" -start
OpenService failed:
The specified service does not exist as an installed service. (error 1060)
It seems the installer is not installing the service as would be
expected under Windows Vista Home Ultimate.
At least not on my new Dell XPS 410.
I can force the install using smpd.exe -install, but I am still unable
to use wmpiexec (I am able to use mpiexec somewhat).
Brian
Jayesh Krishna wrote:
>  Hi,
>   The smpd passphrase is the passphrase that the user specifies during the
> MPICH2 installation process (By default the passphrase is set to "behappy"
> and the user has the option of changing it. The user is prompted for the
> same during the MPICH2 installation).
>   You don't have to run "smpd.exe -install" to get smpd running on your
> system. During a successful installation this is done for you by the
> installer.
>   I would recommend that you re-install MPICH2 on your system (after
> uninstalling the existing version of MPICH2). Please try rebooting your
> system before running mpiexec. Initially try running some simple command
> like "mpiexec -n 1 dir". Then try running "mpiexec -n 2 cpi.exe" (cpi.exe is
> provided with 32-bit version of MPICH2 in <INSTALL-DIR>\MPICH2\examples
> directory)
> Regards,
> Jayesh
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Brian Andrus
> Sent: Sunday, February 03, 2008 2:24 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] MPICH2 with MS Vista
> I am trying to get MPICH2 working all around with MS Vista. I have installed
> it and I can get a simple hello world to run in the console, but I would
> like to use wmpiexec to run things too. Unfortunately, every time I try to
> run my hello world, I get an error:
> Error: No smpd passphrase specified through the registry or .smpd file,
> exiting.
> When I run wmpiconfig and try to scan hosts, I get:
> Please specify an authentication passphrase for smpd: 1.0.6
> I run wmpiregister and use my logged in username/password, which seems
> to register (wmpiconfig runs this automatically if there is no
> account/pass in the registry).
> I noticed a few things:
> 1) I cannot run the installer as an administrator (the option isn't
> there when I right click on a .msi file)
> 2) After the install, I needed to open a console administrator and then
> run "smpd.exe -install" to get the MPICH2 process manager service
> registered, otherwise it would not show up under the services.
> 3) As a normal user, I can run my hello world from a command windows, if
> I have added a user/password using wmpiregister. To do so, I have to
> just hit return when it asks for a passphrase.
> --------------------------snip-------------------------------------
> C:\Users\Brian>"\Program Files\MPICH2\bin\mpiexec.exe" -n 2
> "\Users\Brian\Documents\Visual Studio
> 2008\Projects\HelloWorld\Debug\HelloWorld.exe"
> Hello World from process 0 on Brian-PC
> Number of Processes: 2
> Hello World from process 1 on Brian-PC
> I used MS Visual C++ express 2008 to create my hello world program. I
> did need to set up a couple paths to get the mpi.h libraries included so
> it would compile and link, but it seems to be working and generating
> executable code.
> This is all on a fresh Dell with Vista Home Ultimate installed.
> Any ideas what I am missing to get wmpiexec to work?
> Thanks in advance,
> Brian Andrus
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
