[mpich-discuss] mpich2 1.0.8: problems compiling (simplemake)
Rajeev Thakur thakur at mcs.anl.gov
Tue Dec 30 23:54:42 CST 2008
Gaetano,
                It is not a problem with MPICH2. It is caused by a problem
with time stamps on files in remotely mounted (NFS) directories that cause
the "make" utility to not work properly. If the time on all your machines is
synchronized via NTP, it should work.
Rajeev
  _____
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Bellanca Gaetano
Sent: Tuesday, December 30, 2008 6:29 PM
Subject: Re: [mpich-discuss] mpich2 1.0.8: problems compiling (simplemake)
Dear Rajeev,
it works. Compiling in a sub-directory in /tmp solved the problem. But I'd
like to know the reason. Or, better, I'd like to know if it will be
necessary to do this in the new releases of mpich2. I'm going to compile the
new pre-release, and I'd like to know if I need to compile in /tmp
sub-directories. In all the previous versions, I've never experienced this
problem.
Anyway, thanks a lot for the proposed solution and ... happy new year to you
and to everyone in the list.
Gaetano
  _____
  _____
Gaetano Bellanca - Department of Engineering - University of Ferrara
Via Saragat, 1 - 44100 - Ferrara - ITALY
Voice (VoIP):  +39 0532 974809     Fax:  +39 0532 974870
mailto:gaetano.bellanca at unife.it
"L'istruzione costa? Stanno provando con l'ignoranza!"
  _____
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081230/cf059651/attachment.htm>
