[mpich-discuss] request to enhance jumpshot script for portability
chong tan
chong_guan_tan at yahoo.com
Mon Dec 29 19:05:47 CST 2008
version used : 1.0.8
the current jumpshot script created by config has the JAVA path and MPICH2 installation path hard coded in. This make shipping jumpshot to a different env impossible without hacking.
I am requesting that the jumpshot/jumpshot.in code (in src/mpe2/src/slog2sdk/bin) be enhanced with the following changes:
# Set JAVA environment
if [ "XX${JRE}" = "XX" ] ; then
JVM=<JAVA path during configure>/bin/java ###
else
JVM=${JRE}/bin/java
fi
JVMOPTS="" ###
# Assume user's environmental JVMFLAGS is better than what configure found.
JVMFLAGS=${JVMFLAGS:-${JVMOPTS}} ###
# Set PATH to various jar's needed by the GUI
MPIEXEC_PATH=`which mpiexec`
echo ${MPIEXEC_PATH}
if [ "XX${MPIEXEC_PATH}" = "XX" ] ; then
GUI_LIBDIR=<MPICH2 install path>/lib ###
else
GUI_LIBDIR=$(dirname $(dirname $MPIEXEC_PATH))/lib
fi
where path in <> are hard coded like the existing code. the env var JRE (or any name the MPICH2 group prefers) decides where to pickup the JRE. lines marked ### are lines from 1.0.8 release.
this will make relocating jumpshot to a different system easy.
thanks
tan
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20081229/0cf7dd9e/attachment.htm>
