[mpich-discuss] help in compiling using mpich library
Anthony Chan
chan at mcs.anl.gov
Thu Dec 4 15:25:42 CST 2008
----- "Zubaer Hossain" <zubaexy at gmail.com> wrote:
> Hi,
> I have installed mpich2 in Intel Xeon 7400 series workstation with 8
> processors. I tried to install a code with 'mpif90'. I see the
> following
> error at the end of the compilation
> ld: skipping incompatible /home/hossain2/mpich2-install/lib/libmpich.a
> when
> searching for -lmpich
> ld: skipping incompatible /usr/local/lib/libmpich.a when searching
> for
> -lmpich
> ld: cannot find -lmpich
This could mean that your mpif90 (hence the native F90) creates a different
binary format than libmpich.a's, e.g. one is in 64bit and the other is in 32bit.
Can you check if mpif90 can compile a simple fpi.f ? What compiler flag you
passed to mpif90 ? and how was your mpich2 built (check the output of mpich2version).
A.Chan
> What this incompatibility means?
> Could you please suggest what went wrong. I could succesfully complete
> first
> 8 steps of section 2.2 during installing mpich2. Since this a single
> machine, I didn't follow the rest steps, from 9.
> Thanks in advance,
> Zubaer
