[mpich-discuss] Contiguous memory random access
Robert Kubrick
robertkubrick at gmail.com
Sat Aug 16 08:05:46 CDT 2008
I have the following structure:
struct Employee
char lastName[64];
char firstName[64];
double salary;
I want to allocate an array of 100 employees in memory for use with
MPI collective data transfer and maybe one-sided window operations:
Employee* pEmp = (Employee*)calloc(100, sizeof(Employee));
Now the problem is that I also want to randomly access each slot in
the pEmp array by 'lastName'. Normally I would allocate an STL map
collection indexed by last name to do this, but here I need to
maintain contiguous memory space to run MPI_Scatter/MPI_Gather
collectives.
One way to solve the problem is to maintain a collection that maps
each last name with the relative index in the array. For example:
typedef std::map<std::string, int> MYRANDIDX;
MYRANDIDX _mRandIdx;
MYRANDIDX::const_iterator citer = _mRandIdx.find("Smith");
Employee smith = pEmp[citer->second];
Of course all insert/erase operations must be managed to keep the
random indexing and the contiguous array in sync.
I thought this must be a common problem in MPI and maybe there are
some standard techniques or libraries to manage random indexing on a
contiguous memory array?
