[MPICH] Running on root's MPD as either root or another user
Ralph Butler
rbutler at mtsu.edu
Mon Oct 1 16:54:25 CDT 2007
The key is to make sure the mpd files are installed as setuid-root as
described in the manual.
Here's the relevant blurb:
5.1.6 Running MPD as Root
MPD can run as root to support multiple users simultaneously. To do
this,
it easiest to simply do the “make install” in the mpd sub-directory
as root.
This will cause the mpdroot program to be installed in the bin
directory with
setuid-root permissions.
If things are already installed, you can alter mpdroot's permissions
with the chmod
command, e.g.:
chmod +s mpdroot
--ralph
On MonOct 1, at Mon Oct 1 3:03PM, Matthew Chambers wrote:
> Hi all,
> The install guide seems unclear about how to do this or if it's
> even possible. I have my user's .mpd.conf as:
> MPD_SECRETWORD=foo
> MPD_USE_ROOT_MPD=1
> And my /etc/mpd.conf is:
> MPD_SECRETWORD=foo
> Permissions on the user's conf are: -rwx------
> When permissions on the /etc/mpd.conf are: -rwx------
> I can run mpdtrace and MPI jobs as root just fine, but when I try
> either of those as the user, I get "open failed for root's mpd conf
> filempdtrace: mpd_uncaught_except_tb handling"
> So when I set permissions on the /etc/mpd.conf are: -rwx---r--
> I can run mpdtrace as the user, but when I try to run an MPI job
> (e.g. mpiexec -n 16 hostname ; not an MPI program, but still works
> fine with MPICH2), it hangs. When I break it with CTRL-C I get the
> message "(mpiexec 413): mpiexec: failed to obtain sock from
> manager". I can't run mpdtrace or MPI jobs as root because of:
> "configuration file /etc/mpd.conf is accessible by others \ change
> permissions to allow read and write access only by you". This
> seems a bit of a catch-22.
> I'm mostly interested in getting it working for the user. I don't
> have the MPD binaries installed in the standard location, so I'm
> not sure how to set the permissions. I tried setting everything
> to: -rwxr-sr-x
> But that has the same error. The user only has an account on the
> head node, is that the problem?
> Thanks,
> Matt Chambers
