[MPICH] Running on root's MPD as either root or another user
Matthew Chambers
matthew.chambers at vanderbilt.edu
Mon Oct 1 16:37:19 CDT 2007
I chmod'd both files to 600 and changed MPD_SECRETWORD to secretword,
but I still get the same error on the user because it can't access the
/etc/mpd.conf. I think this must have something to do with the MPD
binaries not being able to setuid to root (which would then allow it to
access root's mpd.conf). But I don't know how to set that up, it seems.
-Matt
Eduardo Kienetz wrote:
> On 10/1/07, Matthew Chambers <matthew.chambers at vanderbilt.edu> wrote:
>> Hi all,
>> The install guide seems unclear about how to do this or if it's even
>> possible. I have my user's .mpd.conf as:
>> MPD_SECRETWORD=foo
>> MPD_USE_ROOT_MPD=1
> My in university Slackware cluster (3 machines for Parallel & Dist.
> Programming class) I've added an .mpd.conf file to /etc/skel/ with:
> secretword=foo
> MPD_USE_ROOT_MPD=1
> chmod 600 /etc/skel/.mpd.conf
> /etc/mpd.conf (chmod 600 too) has only:
> secretword=foo
> So when I create new users their skeleton homedir comes with it already.
> Additionally I've set up NIS to centralize users authentication.
> Anyway, to solve your problem just set permissions to 600 in both
> files and change MPD_SECRETWORD to secretword
> Regards,
