[MPICH] Using MPI_File_write_all()
Christina Patrick christina.subscribes at gmail.com
Tue Nov 13 13:06:45 CST 2007
Thank you very much for clearing my doubts.
Christina.
On Nov 10, 2007 7:46 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> If the successive writes skip an offset of 256 bytes from the start of the
> previous write, then it's doing the right thing. Isn't that what you want?
> For example, P0 writes the first 4 rows in the first iteration, and the
> first 4 rows of the next appended array in the second iteration, which will
> begin at offset 256.
> The spec says
> "After an individual file pointer operation is initiated, the individual
> file pointer is updated to point to the next etype after the last one that
> will be accessed. The file pointer is updated relative to the current view
> of the file."
> at http://www.mpi-forum.org/docs/mpi-20-html/node192.htm
> Rajeev
> > -----Original Message-----
> > From: owner-mpich-discuss at mcs.anl.gov
> > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> > Christina Patrick
> > Sent: Friday, November 09, 2007 4:06 PM
> > To: mpich-discuss-digest at mcs.anl.gov
> > Subject: [MPICH] Using MPI_File_write_all()
> > Hi All,
> > I am trying to write a test program using
> > MPI_File_write_all(). I have defined a file view using MPI
> > derived datatypes. When I write to the file using
> > MPI_File_write_at_all(), I get correct results. However,
> > using the same file view, when I write to the file using
> > MPI_File_write_all(), I get really weird results. My access
> > pattern is as below. The file/array consists of 16 rows and 4
> > columns and the size of the collective buffer is 4 elements
> > (1 row) (all for illustrative purposes only, later I will
> > scale the sizes). First 4 rows are written by P0, next 4 rows
> > are written by P1 and so on.
> > Filesize = 256 bytes and Element Type = MPI_INT
> > |                                         |    P0
> > |                                         |    P1
> > |                                         |    P2
> > |                                         |    P3
> > The first write to the file using MPI_File_write_all() is at
> > the correct offset. However, all writes after the first write using
> > MPI_File_write_all() skip an offset of FILESIZE bytes from
> > its previous write and then writes to the file.
> > The program is as follows:
> > #define N                                   4
> > #define ROWS                           ((N)*4)
> > #define COLS                             (N)
> > #define DATATYPE                     MPI_INT
> > #define SIZEOF_DATATYPE        4
> > #define COLL_BUFSIZE              ((N)*(SIZEOF_DATATYPE))
> > #define ELTS_IN_COLL_BUF      ((COLL_BUFSIZE)/(SIZEOF_DATATYPE))
> > #define FILESIZE
> > ((ROWS)*(COLS)*(SIZEOF_DATATYPE))
> > #define NUM_OF_ITERATIONS   ((FILESIZE)/(COLL_BUFSIZE))
> > #define FILENAME                     "pvfs2:/pvfs2-fs/test"
> > int main(int argc, char **argv) {
> >   // array_of_blocklength                                       //
> > array_of_displacements                     // array_of_types
> >   blen[0] = 1;
> > indices[0] = 0;                                      oldtypes[0] =
> > MPI_LB;
> >   blen[1] = FILESIZE/nprocs/SIZEOF_DATATYPE; indices[1] =
> > mynod*(FILESIZE/nprocs);  oldtypes[1] = DATATYPE;
> >   blen[2] = 1;
> > indices[2] = nprocs*(FILESIZE/nprocs);  oldtypes[2] = MPI_UB;
> >   error_code = MPI_Type_struct(3, blen, indices, oldtypes, &newtype);
> >   MPI_ERR_CHECK(error_code);
> >   error_code = MPI_Type_commit(&newtype);
> >   error_code = MPI_File_set_view(fhC, 0, DATATYPE, newtype,
> > "native", MPI_INFO_NULL);
> >   iterations = (FILESIZE)/(COLL_BUFSIZE)/nprocs;
> >   for(i = 0, offset = 0, count = (ROWS/nprocs)*mynod*COLS; i
> > < iterations; i++, offset += COLS) {
> >     for (j = 0; j < ELTS_IN_COLL_BUF; j++) {
> >       buffer[j] = count++;
> >       fprintf(stdout, "buffer[%d] = %d\n", j, buffer[j]);
> > #if 0 <============================
> >     error_code = MPI_File_write_at_all(fhC, offset, buffer,
> > ELTS_IN_COLL_BUF, DATATYPE, &status); #else
> >     error_code = MPI_File_write_all(fhC, buffer,
> > ELTS_IN_COLL_BUF, DATATYPE, &status); #endif
> >   error_code = MPI_File_close(&fhC);
> > When I use a seek() in with a write_all(), I get the correct
> > results (illustrated as below).
> > error_code = MPI_File_seek(fhC, offset, MPI_SEEK_SET);
> > ELTS_IN_COLL_BUF, DATATYPE, &status); <============================
> > Is MPI_File_write_all() always supposed to be used with a
> > MPI_File_seek() or am I doing something wrong.
> > Could you'll please help me so that I can understand
> > MPI_File_write_all() better. If you'll could also point me to
> > some good documentation, that would help too.
> > Thanks,
> > Christina.
