[MPICH] Error handling issue
AGPX agpxnet at yahoo.it
Sun Nov 11 06:36:43 CST 2007
I have write the following code wishing to avoid my main process to abort on an MPI error:
MPI_Init(&argc, &argv);
MPI_Comm_rank(MPI_COMM_WORLD, &MPIId);
MPI_Comm_size(MPI_COMM_WORLD, &numprocs);
 MPI_Comm_set_errhandler(MPI_COMM_WORLD, MPI_ERRORS_RETURN);
but when I try to terminate a job process on another machine (pcamd3000 is the main machine, pcamd2600 the other. I use Windows XP Pro on both), then the main process abort. Here the error message:
job aborted:
rank: node: exit code[: error message]
0: pcamd3000: 1: Fatal error in MPI_Send: Other MPI error, error stack:
MPI_Send(173).............................: MPI_Send(buf=00B458B0, count=1, MPI_
INT, dest=1, tag=0, comm=0x84000000) failed
MPIDI_CH3I_Progress(148)..................: handle_sock_op failed
MPIDI_CH3I_Progress_handle_sock_event(497):
MPIDU_Sock_wait(2603).....................: Il nome di rete specificato non è più disponibile. (errno 64)
1: pcamd2600: 1: process 1 exited without calling finalize
2: pcamd2600: 1
(note that the message:  'Il nome di rete specificato non è più disponibile.' in english is: 'The network name specified is no more available'.)
What I miss? I have more than one communicator, but I have used MPI_Comm_set_errhandler as well to set their error handler to MPI_ERRORS_RETURN. The code is:
MPI_Group_incl(worldGroup, nRanks, ranks, &handle.group);
MPI_Comm_create(MPI_COMM_WORLD, handle.group, &handle.comm);
MPI_Comm_set_errhandler(handle.comm, MPI_ERRORS_RETURN);
I have also tried with MPI_Errhandler_set, but this doesn't help:
MPI_Errhandler_set(..., MPI_ERRORS_RETURN);
Any suggestion?
- AGPX
      ___________________________________
L'email della prossima generazione? Puoi averla con la nuova Yahoo! Mail: http://it.docs.yahoo.com/nowyoucan.html
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20071111/000ed713/attachment.htm>
