[MPICH] Using MPI_File_write_all()
    Rajeev Thakur
    thakur at mcs.anl.gov
    Sat Nov 10 18:46:37 CST 2007
If the successive writes skip an offset of 256 bytes from the start of the
previous write, then it's doing the right thing. Isn't that what you want?
For example, P0 writes the first 4 rows in the first iteration, and the
first 4 rows of the next appended array in the second iteration, which will
begin at offset 256.
The spec says
"After an individual file pointer operation is initiated, the individual
file pointer is updated to point to the next etype after the last one that
will be accessed. The file pointer is updated relative to the current view
of the file."
at http://www.mpi-forum.org/docs/mpi-20-html/node192.htm
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of
> Christina Patrick
> Sent: Friday, November 09, 2007 4:06 PM
> To: mpich-discuss-digest at mcs.anl.gov
> Subject: [MPICH] Using MPI_File_write_all()
> Hi All,
> I am trying to write a test program using
> MPI_File_write_all(). I have defined a file view using MPI
> derived datatypes. When I write to the file using
> MPI_File_write_at_all(), I get correct results. However,
> using the same file view, when I write to the file using
> MPI_File_write_all(), I get really weird results. My access
> pattern is as below. The file/array consists of 16 rows and 4
> columns and the size of the collective buffer is 4 elements
> (1 row) (all for illustrative purposes only, later I will
> scale the sizes). First 4 rows are written by P0, next 4 rows
> are written by P1 and so on.
> Filesize = 256 bytes and Element Type = MPI_INT
> |                                         |    P0
> |                                         |    P1
> |                                         |    P2
> |                                         |    P3
> The first write to the file using MPI_File_write_all() is at
> the correct offset. However, all writes after the first write using
> MPI_File_write_all() skip an offset of FILESIZE bytes from
> its previous write and then writes to the file.
> The program is as follows:
> #define N                                   4
> #define ROWS                           ((N)*4)
> #define COLS                             (N)
> #define DATATYPE                     MPI_INT
> #define SIZEOF_DATATYPE        4
> #define COLL_BUFSIZE              ((N)*(SIZEOF_DATATYPE))
> #define ELTS_IN_COLL_BUF      ((COLL_BUFSIZE)/(SIZEOF_DATATYPE))
> #define FILESIZE
> ((ROWS)*(COLS)*(SIZEOF_DATATYPE))
> #define NUM_OF_ITERATIONS   ((FILESIZE)/(COLL_BUFSIZE))
> #define FILENAME                     "pvfs2:/pvfs2-fs/test"
> int main(int argc, char **argv) {
>   // array_of_blocklength                                       //
> array_of_displacements                     // array_of_types
>   blen[0] = 1;
> indices[0] = 0;                                      oldtypes[0] =
> MPI_LB;
>   blen[1] = FILESIZE/nprocs/SIZEOF_DATATYPE; indices[1] =
> mynod*(FILESIZE/nprocs);  oldtypes[1] = DATATYPE;
>   blen[2] = 1;
> indices[2] = nprocs*(FILESIZE/nprocs);  oldtypes[2] = MPI_UB;
>   error_code = MPI_Type_struct(3, blen, indices, oldtypes, &newtype);
>   MPI_ERR_CHECK(error_code);
>   error_code = MPI_Type_commit(&newtype);
>   error_code = MPI_File_set_view(fhC, 0, DATATYPE, newtype,
> "native", MPI_INFO_NULL);
>   iterations = (FILESIZE)/(COLL_BUFSIZE)/nprocs;
>   for(i = 0, offset = 0, count = (ROWS/nprocs)*mynod*COLS; i
> < iterations; i++, offset += COLS) {
>     for (j = 0; j < ELTS_IN_COLL_BUF; j++) {
>       buffer[j] = count++;
>       fprintf(stdout, "buffer[%d] = %d\n", j, buffer[j]);
> #if 0 <============================
>     error_code = MPI_File_write_at_all(fhC, offset, buffer,
> ELTS_IN_COLL_BUF, DATATYPE, &status); #else
>     error_code = MPI_File_write_all(fhC, buffer,
> ELTS_IN_COLL_BUF, DATATYPE, &status); #endif
>   error_code = MPI_File_close(&fhC);
> When I use a seek() in with a write_all(), I get the correct
> results (illustrated as below).
> error_code = MPI_File_seek(fhC, offset, MPI_SEEK_SET);
> ELTS_IN_COLL_BUF, DATATYPE, &status); <============================
> Is MPI_File_write_all() always supposed to be used with a
> MPI_File_seek() or am I doing something wrong.
> Could you'll please help me so that I can understand
> MPI_File_write_all() better. If you'll could also point me to
> some good documentation, that would help too.
> Thanks,
> Christina.
