[MPICH] Using MPI_File_write_all()
Christina Patrick
christina.subscribes at gmail.com
Fri Nov 9 16:06:02 CST 2007
Hi All,
I am trying to write a test program using MPI_File_write_all(). I have
defined a file view using MPI derived datatypes. When I write to the
file using MPI_File_write_at_all(), I get correct results. However,
using the same file view, when I write to the file using
MPI_File_write_all(), I get really weird results. My access pattern is
as below. The file/array consists of 16 rows and 4 columns and the
size of the collective buffer is 4 elements (1 row) (all for
illustrative purposes only, later I will scale the sizes). First 4
rows are written by P0, next 4 rows are written by P1 and so on.
Filesize = 256 bytes and Element Type = MPI_INT
| | P0
| | P1
| | P2
| | P3
The first write to the file using MPI_File_write_all() is at the
correct offset. However, all writes after the first write using
MPI_File_write_all() skip an offset of FILESIZE bytes from its
previous write and then writes to the file.
The program is as follows:
#define N 4
#define ROWS ((N)*4)
#define COLS (N)
#define DATATYPE MPI_INT
#define SIZEOF_DATATYPE 4
#define COLL_BUFSIZE ((N)*(SIZEOF_DATATYPE))
#define ELTS_IN_COLL_BUF ((COLL_BUFSIZE)/(SIZEOF_DATATYPE))
#define FILESIZE ((ROWS)*(COLS)*(SIZEOF_DATATYPE))
#define NUM_OF_ITERATIONS ((FILESIZE)/(COLL_BUFSIZE))
#define FILENAME "pvfs2:/pvfs2-fs/test"
int main(int argc, char **argv) {
// array_of_blocklength //
array_of_displacements // array_of_types
blen[0] = 1;
indices[0] = 0; oldtypes[0] =
MPI_LB;
blen[1] = FILESIZE/nprocs/SIZEOF_DATATYPE; indices[1] =
mynod*(FILESIZE/nprocs); oldtypes[1] = DATATYPE;
blen[2] = 1;
indices[2] = nprocs*(FILESIZE/nprocs); oldtypes[2] = MPI_UB;
error_code = MPI_Type_struct(3, blen, indices, oldtypes, &newtype);
MPI_ERR_CHECK(error_code);
error_code = MPI_Type_commit(&newtype);
error_code = MPI_File_set_view(fhC, 0, DATATYPE, newtype, "native",
MPI_INFO_NULL);
iterations = (FILESIZE)/(COLL_BUFSIZE)/nprocs;
for(i = 0, offset = 0, count = (ROWS/nprocs)*mynod*COLS; i <
iterations; i++, offset += COLS) {
for (j = 0; j < ELTS_IN_COLL_BUF; j++) {
buffer[j] = count++;
fprintf(stdout, "buffer[%d] = %d\n", j, buffer[j]);
#if 0 <============================
error_code = MPI_File_write_at_all(fhC, offset, buffer,
ELTS_IN_COLL_BUF, DATATYPE, &status);
#else <============================
error_code = MPI_File_write_all(fhC, buffer, ELTS_IN_COLL_BUF,
DATATYPE, &status);
#endif <============================
error_code = MPI_File_close(&fhC);
When I use a seek() in with a write_all(), I get the correct results
(illustrated as below).
error_code = MPI_File_seek(fhC, offset, MPI_SEEK_SET);
DATATYPE, &status);
Is MPI_File_write_all() always supposed to be used with a
MPI_File_seek() or am I doing something wrong.
Could you'll please help me so that I can understand
MPI_File_write_all() better. If you'll could also point me to some
good documentation, that would help too.
Christina.
