[MPICH] debug flag
Wei-keng Liao
wkliao at ece.northwestern.edu
Fri May 25 17:35:16 CDT 2007
Rob,
I can see from adio/common/malloc.c that if malloc(), calloc(), or
realloc() fails, an error message "Out of memory in file ..." will be
printed and MPI_Abort(MPI_COMM_WORLD, 1) called. But, I did not see the
"Out of memory" in my error message.
If the MPICH2 is not configured with --enable-g=dbg, will
FPRINTF(stderr, "Out of memory in file %s, line %d\n", fname, lineno);
be seen?
I have sent email to the system and ask what options were used for that
build of MPICH2-1.0.2.
If it was built without option --enable-g=dbg, what debug flags I can use
to get as much error info from MPICH as possible?
Wei-keng
On Fri, 25 May 2007, Robert Latham wrote:
> On Fri, May 25, 2007 at 03:56:16PM -0500, Wei-keng Liao wrote:
>> I have an MPI I/O application that runs fine up to 1000 processes, but
>> failed when using 4000 processes. Parts of error message are
>> Stack Trace: ------------------------------
>> #0 0x00000000002d46fe in ADIOI_Calc_my_req()
>> #1 0x00000000002d2280 in ADIOI_GEN_WriteStridedColl()
>> #2 0x00000000002a397c in MPIOI_File_write_all()
>> #3 0x00000000002a3a4a in PMPI_File_write_all()
>> #4 0x00000000002913a8 in pmpi_file_write_all_()
>> could not find symbol for addr 0x73696e6966204f49
>> aborting job:
>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1456
>> My question is what debug flags should I use for compiling and running in
>> order to help find what exact location in function ADIOI_Calc_my_req()
>> causes this error?
> Hi Wei-keng
> If you build MPICH2 with --enable-g=dbg, then all of MPI will be built
> with debugging symbols. Be sure to 'make clean' first: the ROMIO
> objects might not rebuild otherwise.
> I wonder what caused the abort? maybe ADIOI_Malloc failed to allocate
> memory? Well, a stack trace with debugging symbols should be
> interesting.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division A215 0178 EA2D B059 8CDF
> Argonne National Lab, IL USA B29D F333 664A 4280 315B
