[MPICH] debug flag
Robert Latham robl at mcs.anl.gov
Wed May 30 14:30:37 CDT 2007
On Wed, May 30, 2007 at 01:28:45PM -0500, Wei-keng Liao wrote:
> The code file is attached. The command-line arguments are
>   "filename npx npy npz", where filename is the name of output file, and
>   npx, npy, npz are the number of processes along X-Y-Z dimensions.
> The XYZ dimensions in each subarray is fixed to 50 x 50 x 50. Each array
> element is a double type. The global array size is hence proportional to
> the number of processes. There is a fourth dimension of size 11, but not
> partitioned.
We have a problem in that MPI datatypes are used for both memory (32
bit pointers) and files (64 bit file offsets/sizes), and we can have a
situation where 64 bit values (file sizes or offsets) are stuffed into
32 bit variables (as you saw in your previous message).
We're working on a way around this problem.  We have to solve it for
PnetCDF as well.
==rob
Rob Latham
Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
Argonne National Lab, IL USA                 B29D F333 664A 4280 315B
