[MPICH] Compiling MPICH2 with the intel compiler
Andrew Hakman
andrew.hakman at gmail.com
Fri May 25 15:34:37 CDT 2007
Hi
I seem to be having an issue compiling MPICH2 with the intel C/C++
compiler. The config script seems to get stuck determining the size of
bool. Undefining CC and CXX environment variables (so it's using gcc
and g++), the config script runs fine.
Attached is the config output.
Any suggestions?
Thanks
Andrew
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070525/948c928c/attachment.obj>
