[MPICH] Compiling MPICH2 with the intel compiler
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri May 25 16:30:54 CDT 2007
Does the C++ compiler icpc work, i.e., can you compile a simple C++ program?
If you don't need C++, you can configure with --disable-cxx.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Andrew Hakman
> Sent: Friday, May 25, 2007 3:35 PM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] Compiling MPICH2 with the intel compiler
> Hi
> I seem to be having an issue compiling MPICH2 with the intel C/C++
> compiler. The config script seems to get stuck determining the size of
> bool. Undefining CC and CXX environment variables (so it's using gcc
> and g++), the config script runs fine.
> Attached is the config output.
> Any suggestions?
> Thanks
> Andrew
