[MPICH] MPI-IO, vector datatype
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri May  4 00:07:34 CDT 2007
OK, I am no C++ expert, but if I define a datatype
MPI::Datatype newtype;
and do
newtype =  filetype.Create_vector(...)
newtype.Commit();
And then pass newtype as the filetype to Set_view in both places, your code
works.
Rajeev
> -----Original Message-----
> From: Russell L. Carter [mailto:rcarter at esturion.net]
> Sent: Thursday, May 03, 2007 11:57 PM
> To: Rajeev Thakur
> Cc: 'Rob Ross'; mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] MPI-IO, vector datatype
> All right, I've been thinking, ok, I'm an old fart,
> I can revert to assembly code. :-)
> I will provide you with the direct analogue in c tomorrow.
> Now that I think about it, it's quite possible that I was wrong
> about the c++ api not being a problem, as there may be a
> missing & (reference) operator somewhere.
> Best,
> Russell
> Rajeev Thakur wrote:
> > I don't see any bug in the program, so I am guessing it has
> to do with C++,
> > may be even the C++ binding in MPICH2. Can you run the C
> version of the
> > program you downloaded from the book.
> > Rajeev
> >> Sent: Thursday, May 03, 2007 11:35 PM
> >> To: Rajeev Thakur
> >>> Can you try writing to /tmp in case /home/rcarter is NFS.
> >> Yes indeed, NFS is problematical no?  Generally it fails, as
> >> I discovered today.  Probably from the error messages I need
> >> to enforce sync semantics.  But after running into these problems
> >> I settled back on testing with multiple process single filesystem,
> >> using the local unix fs, or multiple node global pvfs2 filesystems
> >> I have.
> >> So yes, those last od dumps are from a single system, single
> >> filesystem.  Specifically a linux 2.6 kernel with 2 cpus and
> >> a lot of fast disk.
> >> I might add that I admin all these systems and have been doing
> >> this sort of stuff for 17 years so any underlying (re)configuration
> >> that might help is not out of the question to try out.
> >> But I don't think that's the problem.
> >> Best,
> >> Russell
> >>> Rajeev
> >>>> Sent: Thursday, May 03, 2007 9:03 PM
> >>>> To: Rob Ross
> >>>> Cc: Rajeev Thakur; mpich-discuss at mcs.anl.gov
> >>>> Hi Rob,
> >>>> Rob Ross wrote:
> >>>>> Hi Russell,
> >>>>> The "nblocks(1)" sets that variable to 1, yes? Sorry, C++
> >>>> isn't my thing.
> >>>> Well, I mentioned that I tried multiple values for nblocks:
> >>>> 1, 2, and 4,
> >>>> for instance.  It would only increase the lines of code to add in
> >>>> a command line argument and I wanted to keep the code as small
> >>>> as possible, and it surely is.
> >>>> To get the wrong result, set nblocks to 2: nblocks(2).
> >>>> I'd like to emphasize that I have tried to change nothing about
> >>>> the algorithm in the read_all.c program featured on p.
> 65. of Using
> >>>> MPI-2.   Using that algorithm, I can't write a file and then
> >>>> read it with the same view.  My c++ code is written to make
> >>>> that especially clear.  The c++ code in mpicxx.h is just dead
> >>>> simple inline calls to the c api, so it's not a c++ problem.
> >>>> Maybe I'm wrong (cool, problem solved), and there's a
> >> working example
> >>>> somewhere?  That would be great.
> >>>> Best,
> >>>> Russell
> >>>>> A vector with a count of 1 is the same as a contig with a
> >>>> count equal to
> >>>>> the blocksize of the vector. This would explain what you're
> >>>> seeing. The
> >>>>> stride is only used if the count is greater than 1.
> >>>>> Regards,
> >>>>> Rob
> >>>>> Russell L. Carter wrote:
> >>>>>>> It is easy to run on a single machine. With MPD, all you
> >>>> need to do is
> >>>>>>> % mpd &
> >>>>>>> % mpiexec -n 2 a.out
> >>>>>> Works great.  No difference between pvfs2 and unix.
> >>>>>>> blocks of 4 ints each because you have defined INTS_PER_BLK=4.
> >>>>>> I'm guilty of a transcription error, crap.  Sorry about that,
> >>>>>> that's a stupid waste of time.  Should have been
> INTS_PER_BLK=8.
> >>>>>> With INTS_PER_BLK=4, I agree with your values but the problem
> >>>>>> is still there.  I have found what appears to be the problem.
> >>>>>> The stride arg in the Create_vector method appears to be
> >>>>>> ignored.  It doesn't matter what I set it to, 0 on up to
> >>>>>> nprocs*blocksize, the block data for each proc is written
> >>>>>> out contiguously.
> >>>>>> If I set the view displacement to be myrank*nints,
> >>>>>> the file always looks like this, without
> >>>>>> any holes, for any number of blocks and stride I set
> >>>>>> (nprocs is 2, neg is rank 0, pos is rank 1):
> >>>>>> 0000000           0          -1          -2          -3
> >>>>>> 0000020          -4          -5          -6          -7
> >>>>>> 0000040          -8          -9         -10         -11
> >>>>>> 0000060         -12         -13         -14         -15
> >>>>>> 0000100         -16         -17         -18         -19
> >>>>>> 0000120         -20         -21         -22         -23
> >>>>>> 0000140         -24         -25         -26         -27
> >>>>>> 0000160         -28         -29         -30         -31
> >>>>>> 0000200           0           1           2           3
> >>>>>> 0000220           4           5           6           7
> >>>>>> 0000240           8           9          10          11
> >>>>>> 0000260          12          13          14          15
> >>>>>> 0000300          16          17          18          19
> >>>>>> 0000320          20          21          22          23
> >>>>>> 0000340          24          25          26          27
> >>>>>> 0000360          28          29          30          31
> >>>>>> If I set the view displacements to
> >>>>>> blocksize*sizeof(int)*myrank, the file looks like this,
> >>>>>> for any stride (nblocks/proc is 2 here):
> >>>>>> 0000000           0          -1          -2          -3
> >>>>>> 0000020          -4          -5          -6          -7
> >>>>>> 0000100           0           1           2           3
> >>>>>> 0000120           4           5           6           7
> >>>>>> 0000140           8           9          10          11
> >>>>>> 0000160          12          13          14          15
> >>>>>> 0000200          16          17          18          19
> >>>>>> 0000220          20          21          22          23
> >>>>>> 0000240          24          25          26          27
> >>>>>> 0000260          28          29          30          31
> >>>>>> The further reduced code is appended.  As far as I can tell
> >>>>>> it should produce identical datatypes and views as the program
> >>>>>> on p. 65 of Using MPI-2.  It was my impression that that
> >>>>>> program was intended to read interleaved data, maybe it's
> >>>>>> not?
> >>>>>> Thanks,
> >>>>>> Russell
> >>>>>> #include "mpi.h"
> >>>>>> #include <iostream>
> >>>>>> using namespace std;
> >>>>>> struct tester
> >>>>>>     tester()
> >>>>>>         : myrank(MPI::COMM_WORLD.Get_rank()),
> >>>>>>           nprocs(MPI::COMM_WORLD.Get_size()),
> >>>>>>           bufsize(FILESIZE/nprocs), nints(bufsize/sizeof(int)),
> >>>>>>           nblocks(1), blocksize(nints/nblocks),
> >>>>>>           filetype(MPI::INT),
> >>>>>>           //fname("pvfs2:/mnt/pvfs/tst/testfile")
> >>>>>>           fname("/home/rcarter/mpibin/testfile")
> >>>>>>         std::ios::sync_with_stdio(false);
> >>>>>>         filetype.Create_vector(nblocks, blocksize, nprocs
> >>>> * blocksize);
> >>>>>>         filetype.Commit();
> >>>>>>         obuf = new int[bufsize];
> >>>>>>         ibuf = new int[bufsize];
> >>>>>>     ~tester() {
> >>>>>>         delete[] obuf;
> >>>>>>         delete[] ibuf;
> >>>>>>     void write()
> >>>>>>         for (int i = 0; i < nints; ++i) {
> >>>>>>             if (myrank)
> >>>>>>                 obuf[i] = i;
> >>>>>>             else
> >>>>>>                 obuf[i] = -i;
> >>>>>>         MPI::File f = open_set_view(MPI_MODE_CREATE |
> >>>> MPI_MODE_WRONLY);
> >>>>>>         f.Write_all(obuf, nints, MPI_INT, status);
> >>>>>>         f.Close();
> >>>>>>     void read()
> >>>>>>         MPI::File f = open_set_view(MPI_MODE_RDONLY);
> >>>>>>         f.Read_all(ibuf, nints, MPI_INT, status);
> >>>>>>         f.Close();
> >>>>>>             if (obuf[i] != ibuf[i]) {
> >>>>>>                 cerr << "myrank, i, obuf[i], ibuf[i]: " <<
> >>>> myrank << " "
> >>>>>>                      << i << " " << obuf[i] << " " <<
> >>>> ibuf[i] << endl;
> >>>>>> private:
> >>>>>>     static const int FILESIZE = 256;
> >>>>>>     int myrank, nprocs, bufsize, nints, nblocks,
> >>>> blocksize, *obuf, *ibuf;
> >>>>>>     MPI::Datatype filetype;
> >>>>>>     string fname;
> >>>>>>     MPI::Status status;
> >>>>>>     MPI::File open_set_view(int mode)
> >>>>>>         MPI::File f = MPI::File::Open(MPI::COMM_WORLD,
> >>>> fname.c_str(),
> >>>>>>                                       mode, MPI::INFO_NULL);
> >>>>>>         MPI::Offset disp = blocksize * sizeof(int) * myrank;
> >>>>>>         f.Set_view(disp, MPI_INT, filetype, "native",
> >>>> MPI_INFO_NULL);
> >>>>>>         return f;
> >>>>>> int main()
> >>>>>>     cerr << "Starting rwall.\n";
> >>>>>>     try {
> >>>>>>         MPI::Init();
> >>>>>>         tester t;
> >>>>>>         t.write();
> >>>>>>         MPI::COMM_WORLD.Barrier();
> >>>>>>         t.read();
> >>>>>>         MPI::Finalize();
> >>>>>>     } catch (exception &e) {
> >>>>>>         cerr << "\nCaught exception: " << e.what() << endl;
> >>>>>>         return -1;
> >>>>>>     } catch (MPI::Exception& e) {
> >>>>>>         cerr << "\nError:\n" << e.Get_error_string();
> >>>>>>         return -2;
> >>>>>>     cerr << "rwall end.\n";
> >>>>>>     return 0;
> >>>> Russell L. Carter
> >>>> Esturion, LLC
> >>>> 2285 Sandia Drive
> >>>> Prescott, Arizona 86301
> >>>> 928 308-4154
> >> Russell L. Carter
> >> Esturion, LLC
> >> 2285 Sandia Drive
> >> 928 308-4154
> Russell L. Carter
> Esturion, LLC
> 2285 Sandia Drive
> 928 308-4154
