[MPICH] MPI-IO, vector datatype
Russell L. Carter
rcarter at esturion.net
Fri May 4 00:27:46 CDT 2007
That appears to be it. That's not conventional
c++ semantics. Damn. It all works perfectly now!
Now I know why there's that effort over at
www.boost.org to sanify the MPI api.
Thank you all, especially Rajeev and Rob for all
your help.
Best,
Russell
Rajeev Thakur wrote:
> OK, I am no C++ expert, but if I define a datatype
> MPI::Datatype newtype;
> and do
> newtype = filetype.Create_vector(...)
> newtype.Commit();
> And then pass newtype as the filetype to Set_view in both places, your code
> works.
> Rajeev
>> -----Original Message-----
>> From: Russell L. Carter [mailto:rcarter at esturion.net]
>> Sent: Thursday, May 03, 2007 11:57 PM
>> To: Rajeev Thakur
>> Cc: 'Rob Ross'; mpich-discuss at mcs.anl.gov
>> Subject: Re: [MPICH] MPI-IO, vector datatype
>> All right, I've been thinking, ok, I'm an old fart,
>> I can revert to assembly code. :-)
>> I will provide you with the direct analogue in c tomorrow.
>> Now that I think about it, it's quite possible that I was wrong
>> about the c++ api not being a problem, as there may be a
>> missing & (reference) operator somewhere.
>> Best,
>> Russell
>>> I don't see any bug in the program, so I am guessing it has
>> to do with C++,
>>> may be even the C++ binding in MPICH2. Can you run the C
>> version of the
>>> program you downloaded from the book.
>>> Rajeev
>>>> Sent: Thursday, May 03, 2007 11:35 PM
>>>> To: Rajeev Thakur
>>>>> Can you try writing to /tmp in case /home/rcarter is NFS.
>>>> Yes indeed, NFS is problematical no? Generally it fails, as
>>>> I discovered today. Probably from the error messages I need
>>>> to enforce sync semantics. But after running into these problems
>>>> I settled back on testing with multiple process single filesystem,
>>>> using the local unix fs, or multiple node global pvfs2 filesystems
>>>> I have.
>>>> So yes, those last od dumps are from a single system, single
>>>> filesystem. Specifically a linux 2.6 kernel with 2 cpus and
>>>> a lot of fast disk.
>>>> I might add that I admin all these systems and have been doing
>>>> this sort of stuff for 17 years so any underlying (re)configuration
>>>> that might help is not out of the question to try out.
>>>> But I don't think that's the problem.
>>>> Best,
>>>> Russell
>>>>> Rajeev
>>>>>> Sent: Thursday, May 03, 2007 9:03 PM
>>>>>> To: Rob Ross
>>>>>> Cc: Rajeev Thakur; mpich-discuss at mcs.anl.gov
>>>>>> Hi Rob,
>>>>>> Rob Ross wrote:
>>>>>>> Hi Russell,
>>>>>>> The "nblocks(1)" sets that variable to 1, yes? Sorry, C++
>>>>>> isn't my thing.
>>>>>> Well, I mentioned that I tried multiple values for nblocks:
>>>>>> 1, 2, and 4,
>>>>>> for instance. It would only increase the lines of code to add in
>>>>>> a command line argument and I wanted to keep the code as small
>>>>>> as possible, and it surely is.
>>>>>> To get the wrong result, set nblocks to 2: nblocks(2).
>>>>>> I'd like to emphasize that I have tried to change nothing about
>>>>>> the algorithm in the read_all.c program featured on p.
>> 65. of Using
>>>>>> MPI-2. Using that algorithm, I can't write a file and then
>>>>>> read it with the same view. My c++ code is written to make
>>>>>> that especially clear. The c++ code in mpicxx.h is just dead
>>>>>> simple inline calls to the c api, so it's not a c++ problem.
>>>>>> Maybe I'm wrong (cool, problem solved), and there's a
>>>> working example
>>>>>> somewhere? That would be great.
>>>>>> Best,
>>>>>> Russell
>>>>>>> A vector with a count of 1 is the same as a contig with a
>>>>>> count equal to
>>>>>>> the blocksize of the vector. This would explain what you're
>>>>>> seeing. The
>>>>>>> stride is only used if the count is greater than 1.
>>>>>>> Regards,
>>>>>>> Rob
>>>>>>> Russell L. Carter wrote:
>>>>>>>>> It is easy to run on a single machine. With MPD, all you
>>>>>> need to do is
>>>>>>>>> % mpd &
>>>>>>>>> % mpiexec -n 2 a.out
>>>>>>>> Works great. No difference between pvfs2 and unix.
>>>>>>>>> blocks of 4 ints each because you have defined INTS_PER_BLK=4.
>>>>>>>> I'm guilty of a transcription error, crap. Sorry about that,
>>>>>>>> that's a stupid waste of time. Should have been
>> INTS_PER_BLK=8.
>>>>>>>> With INTS_PER_BLK=4, I agree with your values but the problem
>>>>>>>> is still there. I have found what appears to be the problem.
>>>>>>>> The stride arg in the Create_vector method appears to be
>>>>>>>> ignored. It doesn't matter what I set it to, 0 on up to
>>>>>>>> nprocs*blocksize, the block data for each proc is written
>>>>>>>> out contiguously.
>>>>>>>> If I set the view displacement to be myrank*nints,
>>>>>>>> the file always looks like this, without
>>>>>>>> any holes, for any number of blocks and stride I set
>>>>>>>> (nprocs is 2, neg is rank 0, pos is rank 1):
>>>>>>>> 0000000 0 -1 -2 -3
>>>>>>>> 0000020 -4 -5 -6 -7
>>>>>>>> 0000040 -8 -9 -10 -11
>>>>>>>> 0000060 -12 -13 -14 -15
>>>>>>>> 0000100 -16 -17 -18 -19
>>>>>>>> 0000120 -20 -21 -22 -23
>>>>>>>> 0000140 -24 -25 -26 -27
>>>>>>>> 0000160 -28 -29 -30 -31
>>>>>>>> 0000200 0 1 2 3
>>>>>>>> 0000220 4 5 6 7
>>>>>>>> 0000240 8 9 10 11
>>>>>>>> 0000260 12 13 14 15
>>>>>>>> 0000300 16 17 18 19
>>>>>>>> 0000320 20 21 22 23
>>>>>>>> 0000340 24 25 26 27
>>>>>>>> 0000360 28 29 30 31
>>>>>>>> If I set the view displacements to
>>>>>>>> blocksize*sizeof(int)*myrank, the file looks like this,
>>>>>>>> for any stride (nblocks/proc is 2 here):
>>>>>>>> 0000000 0 -1 -2 -3
>>>>>>>> 0000020 -4 -5 -6 -7
>>>>>>>> 0000100 0 1 2 3
>>>>>>>> 0000120 4 5 6 7
>>>>>>>> 0000140 8 9 10 11
>>>>>>>> 0000160 12 13 14 15
>>>>>>>> 0000200 16 17 18 19
>>>>>>>> 0000220 20 21 22 23
>>>>>>>> 0000240 24 25 26 27
>>>>>>>> 0000260 28 29 30 31
>>>>>>>> The further reduced code is appended. As far as I can tell
>>>>>>>> it should produce identical datatypes and views as the program
>>>>>>>> on p. 65 of Using MPI-2. It was my impression that that
>>>>>>>> program was intended to read interleaved data, maybe it's
>>>>>>>> not?
>>>>>>>> Thanks,
>>>>>>>> Russell
>>>>>>>> #include "mpi.h"
>>>>>>>> #include <iostream>
>>>>>>>> using namespace std;
>>>>>>>> struct tester
>>>>>>>> tester()
>>>>>>>> : myrank(MPI::COMM_WORLD.Get_rank()),
>>>>>>>> nprocs(MPI::COMM_WORLD.Get_size()),
>>>>>>>> bufsize(FILESIZE/nprocs), nints(bufsize/sizeof(int)),
>>>>>>>> nblocks(1), blocksize(nints/nblocks),
>>>>>>>> filetype(MPI::INT),
>>>>>>>> //fname("pvfs2:/mnt/pvfs/tst/testfile")
>>>>>>>> fname("/home/rcarter/mpibin/testfile")
>>>>>>>> std::ios::sync_with_stdio(false);
>>>>>>>> filetype.Create_vector(nblocks, blocksize, nprocs
>>>>>> * blocksize);
>>>>>>>> filetype.Commit();
>>>>>>>> obuf = new int[bufsize];
>>>>>>>> ibuf = new int[bufsize];
>>>>>>>> ~tester() {
>>>>>>>> delete[] obuf;
>>>>>>>> delete[] ibuf;
>>>>>>>> void write()
>>>>>>>> for (int i = 0; i < nints; ++i) {
>>>>>>>> if (myrank)
>>>>>>>> obuf[i] = i;
>>>>>>>> else
>>>>>>>> obuf[i] = -i;
>>>>>>>> MPI::File f = open_set_view(MPI_MODE_CREATE |
>>>>>> MPI_MODE_WRONLY);
>>>>>>>> f.Write_all(obuf, nints, MPI_INT, status);
>>>>>>>> f.Close();
>>>>>>>> void read()
>>>>>>>> MPI::File f = open_set_view(MPI_MODE_RDONLY);
>>>>>>>> f.Read_all(ibuf, nints, MPI_INT, status);
>>>>>>>> f.Close();
>>>>>>>> if (obuf[i] != ibuf[i]) {
>>>>>>>> cerr << "myrank, i, obuf[i], ibuf[i]: " <<
>>>>>> myrank << " "
>>>>>>>> << i << " " << obuf[i] << " " <<
>>>>>> ibuf[i] << endl;
>>>>>>>> private:
>>>>>>>> static const int FILESIZE = 256;
>>>>>>>> int myrank, nprocs, bufsize, nints, nblocks,
>>>>>> blocksize, *obuf, *ibuf;
>>>>>>>> MPI::Datatype filetype;
>>>>>>>> string fname;
>>>>>>>> MPI::Status status;
>>>>>>>> MPI::File open_set_view(int mode)
>>>>>>>> MPI::File f = MPI::File::Open(MPI::COMM_WORLD,
>>>>>> fname.c_str(),
>>>>>>>> mode, MPI::INFO_NULL);
>>>>>>>> MPI::Offset disp = blocksize * sizeof(int) * myrank;
>>>>>>>> f.Set_view(disp, MPI_INT, filetype, "native",
>>>>>> MPI_INFO_NULL);
>>>>>>>> return f;
>>>>>>>> int main()
>>>>>>>> cerr << "Starting rwall.\n";
>>>>>>>> try {
>>>>>>>> MPI::Init();
>>>>>>>> tester t;
>>>>>>>> t.write();
>>>>>>>> MPI::COMM_WORLD.Barrier();
>>>>>>>> t.read();
>>>>>>>> MPI::Finalize();
>>>>>>>> } catch (exception &e) {
>>>>>>>> cerr << "\nCaught exception: " << e.what() << endl;
>>>>>>>> return -1;
>>>>>>>> } catch (MPI::Exception& e) {
>>>>>>>> cerr << "\nError:\n" << e.Get_error_string();
>>>>>>>> return -2;
>>>>>>>> cerr << "rwall end.\n";
>>>>>>>> return 0;
>>>>>> Russell L. Carter
>>>>>> Esturion, LLC
>>>>>> 2285 Sandia Drive
>>>>>> Prescott, Arizona 86301
>>>>>> 928 308-4154
>>>> Russell L. Carter
>>>> Esturion, LLC
>>>> 2285 Sandia Drive
>>>> 928 308-4154
>> Russell L. Carter
>> Esturion, LLC
>> 2285 Sandia Drive
>> 928 308-4154
Russell L. Carter
Esturion, LLC
2285 Sandia Drive
928 308-4154
