[MPICH] MPI-IO, vector datatype
Russell L. Carter
rcarter at esturion.net
Thu May 3 23:57:25 CDT 2007
All right, I've been thinking, ok, I'm an old fart,
I can revert to assembly code. :-)
I will provide you with the direct analogue in c tomorrow.
Now that I think about it, it's quite possible that I was wrong
about the c++ api not being a problem, as there may be a
missing & (reference) operator somewhere.
Best,
Russell
Rajeev Thakur wrote:
> I don't see any bug in the program, so I am guessing it has to do with C++,
> may be even the C++ binding in MPICH2. Can you run the C version of the
> program you downloaded from the book.
> Rajeev
>> -----Original Message-----
>> From: Russell L. Carter [mailto:rcarter at esturion.net]
>> Sent: Thursday, May 03, 2007 11:35 PM
>> To: Rajeev Thakur
>> Cc: 'Rob Ross'; mpich-discuss at mcs.anl.gov
>> Subject: Re: [MPICH] MPI-IO, vector datatype
>>> Can you try writing to /tmp in case /home/rcarter is NFS.
>> Yes indeed, NFS is problematical no? Generally it fails, as
>> I discovered today. Probably from the error messages I need
>> to enforce sync semantics. But after running into these problems
>> I settled back on testing with multiple process single filesystem,
>> using the local unix fs, or multiple node global pvfs2 filesystems
>> I have.
>> So yes, those last od dumps are from a single system, single
>> filesystem. Specifically a linux 2.6 kernel with 2 cpus and
>> a lot of fast disk.
>> I might add that I admin all these systems and have been doing
>> this sort of stuff for 17 years so any underlying (re)configuration
>> that might help is not out of the question to try out.
>> But I don't think that's the problem.
>> Best,
>> Russell
>>> Rajeev
>>>> Sent: Thursday, May 03, 2007 9:03 PM
>>>> To: Rob Ross
>>>> Cc: Rajeev Thakur; mpich-discuss at mcs.anl.gov
>>>> Hi Rob,
>>>> Rob Ross wrote:
>>>>> Hi Russell,
>>>>> The "nblocks(1)" sets that variable to 1, yes? Sorry, C++
>>>> isn't my thing.
>>>> Well, I mentioned that I tried multiple values for nblocks:
>>>> 1, 2, and 4,
>>>> for instance. It would only increase the lines of code to add in
>>>> a command line argument and I wanted to keep the code as small
>>>> as possible, and it surely is.
>>>> To get the wrong result, set nblocks to 2: nblocks(2).
>>>> I'd like to emphasize that I have tried to change nothing about
>>>> the algorithm in the read_all.c program featured on p. 65. of Using
>>>> MPI-2. Using that algorithm, I can't write a file and then
>>>> read it with the same view. My c++ code is written to make
>>>> that especially clear. The c++ code in mpicxx.h is just dead
>>>> simple inline calls to the c api, so it's not a c++ problem.
>>>> Maybe I'm wrong (cool, problem solved), and there's a
>> working example
>>>> somewhere? That would be great.
>>>> Best,
>>>> Russell
>>>>> A vector with a count of 1 is the same as a contig with a
>>>> count equal to
>>>>> the blocksize of the vector. This would explain what you're
>>>> seeing. The
>>>>> stride is only used if the count is greater than 1.
>>>>> Regards,
>>>>> Rob
>>>>> Russell L. Carter wrote:
>>>>>>> It is easy to run on a single machine. With MPD, all you
>>>> need to do is
>>>>>>> % mpd &
>>>>>>> % mpiexec -n 2 a.out
>>>>>> Works great. No difference between pvfs2 and unix.
>>>>>>> blocks of 4 ints each because you have defined INTS_PER_BLK=4.
>>>>>> I'm guilty of a transcription error, crap. Sorry about that,
>>>>>> that's a stupid waste of time. Should have been INTS_PER_BLK=8.
>>>>>> With INTS_PER_BLK=4, I agree with your values but the problem
>>>>>> is still there. I have found what appears to be the problem.
>>>>>> The stride arg in the Create_vector method appears to be
>>>>>> ignored. It doesn't matter what I set it to, 0 on up to
>>>>>> nprocs*blocksize, the block data for each proc is written
>>>>>> out contiguously.
>>>>>> If I set the view displacement to be myrank*nints,
>>>>>> the file always looks like this, without
>>>>>> any holes, for any number of blocks and stride I set
>>>>>> (nprocs is 2, neg is rank 0, pos is rank 1):
>>>>>> 0000000 0 -1 -2 -3
>>>>>> 0000020 -4 -5 -6 -7
>>>>>> 0000040 -8 -9 -10 -11
>>>>>> 0000060 -12 -13 -14 -15
>>>>>> 0000100 -16 -17 -18 -19
>>>>>> 0000120 -20 -21 -22 -23
>>>>>> 0000140 -24 -25 -26 -27
>>>>>> 0000160 -28 -29 -30 -31
>>>>>> 0000200 0 1 2 3
>>>>>> 0000220 4 5 6 7
>>>>>> 0000240 8 9 10 11
>>>>>> 0000260 12 13 14 15
>>>>>> 0000300 16 17 18 19
>>>>>> 0000320 20 21 22 23
>>>>>> 0000340 24 25 26 27
>>>>>> 0000360 28 29 30 31
>>>>>> If I set the view displacements to
>>>>>> blocksize*sizeof(int)*myrank, the file looks like this,
>>>>>> for any stride (nblocks/proc is 2 here):
>>>>>> 0000000 0 -1 -2 -3
>>>>>> 0000020 -4 -5 -6 -7
>>>>>> 0000100 0 1 2 3
>>>>>> 0000120 4 5 6 7
>>>>>> 0000140 8 9 10 11
>>>>>> 0000160 12 13 14 15
>>>>>> 0000200 16 17 18 19
>>>>>> 0000220 20 21 22 23
>>>>>> 0000240 24 25 26 27
>>>>>> 0000260 28 29 30 31
>>>>>> The further reduced code is appended. As far as I can tell
>>>>>> it should produce identical datatypes and views as the program
>>>>>> on p. 65 of Using MPI-2. It was my impression that that
>>>>>> program was intended to read interleaved data, maybe it's
>>>>>> not?
>>>>>> Thanks,
>>>>>> Russell
>>>>>> #include "mpi.h"
>>>>>> #include <iostream>
>>>>>> using namespace std;
>>>>>> struct tester
>>>>>> tester()
>>>>>> : myrank(MPI::COMM_WORLD.Get_rank()),
>>>>>> nprocs(MPI::COMM_WORLD.Get_size()),
>>>>>> bufsize(FILESIZE/nprocs), nints(bufsize/sizeof(int)),
>>>>>> nblocks(1), blocksize(nints/nblocks),
>>>>>> filetype(MPI::INT),
>>>>>> //fname("pvfs2:/mnt/pvfs/tst/testfile")
>>>>>> fname("/home/rcarter/mpibin/testfile")
>>>>>> std::ios::sync_with_stdio(false);
>>>>>> filetype.Create_vector(nblocks, blocksize, nprocs
>>>> * blocksize);
>>>>>> filetype.Commit();
>>>>>> obuf = new int[bufsize];
>>>>>> ibuf = new int[bufsize];
>>>>>> ~tester() {
>>>>>> delete[] obuf;
>>>>>> delete[] ibuf;
>>>>>> void write()
>>>>>> for (int i = 0; i < nints; ++i) {
>>>>>> if (myrank)
>>>>>> obuf[i] = i;
>>>>>> else
>>>>>> obuf[i] = -i;
>>>>>> MPI::File f = open_set_view(MPI_MODE_CREATE |
>>>> MPI_MODE_WRONLY);
>>>>>> f.Write_all(obuf, nints, MPI_INT, status);
>>>>>> f.Close();
>>>>>> void read()
>>>>>> MPI::File f = open_set_view(MPI_MODE_RDONLY);
>>>>>> f.Read_all(ibuf, nints, MPI_INT, status);
>>>>>> f.Close();
>>>>>> if (obuf[i] != ibuf[i]) {
>>>>>> cerr << "myrank, i, obuf[i], ibuf[i]: " <<
>>>> myrank << " "
>>>>>> << i << " " << obuf[i] << " " <<
>>>> ibuf[i] << endl;
>>>>>> private:
>>>>>> static const int FILESIZE = 256;
>>>>>> int myrank, nprocs, bufsize, nints, nblocks,
>>>> blocksize, *obuf, *ibuf;
>>>>>> MPI::Datatype filetype;
>>>>>> string fname;
>>>>>> MPI::Status status;
>>>>>> MPI::File open_set_view(int mode)
>>>>>> MPI::File f = MPI::File::Open(MPI::COMM_WORLD,
>>>> fname.c_str(),
>>>>>> mode, MPI::INFO_NULL);
>>>>>> MPI::Offset disp = blocksize * sizeof(int) * myrank;
>>>>>> f.Set_view(disp, MPI_INT, filetype, "native",
>>>> MPI_INFO_NULL);
>>>>>> return f;
>>>>>> int main()
>>>>>> cerr << "Starting rwall.\n";
>>>>>> try {
>>>>>> MPI::Init();
>>>>>> tester t;
>>>>>> t.write();
>>>>>> MPI::COMM_WORLD.Barrier();
>>>>>> t.read();
>>>>>> MPI::Finalize();
>>>>>> } catch (exception &e) {
>>>>>> cerr << "\nCaught exception: " << e.what() << endl;
>>>>>> return -1;
>>>>>> } catch (MPI::Exception& e) {
>>>>>> cerr << "\nError:\n" << e.Get_error_string();
>>>>>> return -2;
>>>>>> cerr << "rwall end.\n";
>>>>>> return 0;
>>>> Russell L. Carter
>>>> Esturion, LLC
>>>> 2285 Sandia Drive
>>>> Prescott, Arizona 86301
>>>> 928 308-4154
>> Russell L. Carter
>> Esturion, LLC
>> 2285 Sandia Drive
>> 928 308-4154
Russell L. Carter
Esturion, LLC
2285 Sandia Drive
928 308-4154
