[MPICH] MPI-IO, vector datatype
Rajeev Thakur
thakur at mcs.anl.gov
Thu May 3 23:48:28 CDT 2007
I don't see any bug in the program, so I am guessing it has to do with C++,
may be even the C++ binding in MPICH2. Can you run the C version of the
program you downloaded from the book.
Rajeev
> -----Original Message-----
> From: Russell L. Carter [mailto:rcarter at esturion.net]
> Sent: Thursday, May 03, 2007 11:35 PM
> To: Rajeev Thakur
> Cc: 'Rob Ross'; mpich-discuss at mcs.anl.gov
> Subject: Re: [MPICH] MPI-IO, vector datatype
> Rajeev Thakur wrote:
> > Can you try writing to /tmp in case /home/rcarter is NFS.
> Yes indeed, NFS is problematical no? Generally it fails, as
> I discovered today. Probably from the error messages I need
> to enforce sync semantics. But after running into these problems
> I settled back on testing with multiple process single filesystem,
> using the local unix fs, or multiple node global pvfs2 filesystems
> I have.
> So yes, those last od dumps are from a single system, single
> filesystem. Specifically a linux 2.6 kernel with 2 cpus and
> a lot of fast disk.
> I might add that I admin all these systems and have been doing
> this sort of stuff for 17 years so any underlying (re)configuration
> that might help is not out of the question to try out.
> But I don't think that's the problem.
> Best,
> Russell
> > Rajeev
> >> Sent: Thursday, May 03, 2007 9:03 PM
> >> To: Rob Ross
> >> Cc: Rajeev Thakur; mpich-discuss at mcs.anl.gov
> >> Hi Rob,
> >> Rob Ross wrote:
> >>> Hi Russell,
> >>> The "nblocks(1)" sets that variable to 1, yes? Sorry, C++
> >> isn't my thing.
> >> Well, I mentioned that I tried multiple values for nblocks:
> >> 1, 2, and 4,
> >> for instance. It would only increase the lines of code to add in
> >> a command line argument and I wanted to keep the code as small
> >> as possible, and it surely is.
> >> To get the wrong result, set nblocks to 2: nblocks(2).
> >> I'd like to emphasize that I have tried to change nothing about
> >> the algorithm in the read_all.c program featured on p. 65. of Using
> >> MPI-2. Using that algorithm, I can't write a file and then
> >> read it with the same view. My c++ code is written to make
> >> that especially clear. The c++ code in mpicxx.h is just dead
> >> simple inline calls to the c api, so it's not a c++ problem.
> >> Maybe I'm wrong (cool, problem solved), and there's a
> working example
> >> somewhere? That would be great.
> >> Best,
> >> Russell
> >>> A vector with a count of 1 is the same as a contig with a
> >> count equal to
> >>> the blocksize of the vector. This would explain what you're
> >> seeing. The
> >>> stride is only used if the count is greater than 1.
> >>> Regards,
> >>> Rob
> >>> Russell L. Carter wrote:
> >>>>> It is easy to run on a single machine. With MPD, all you
> >> need to do is
> >>>>> % mpd &
> >>>>> % mpiexec -n 2 a.out
> >>>> Works great. No difference between pvfs2 and unix.
> >>>>> blocks of 4 ints each because you have defined INTS_PER_BLK=4.
> >>>> I'm guilty of a transcription error, crap. Sorry about that,
> >>>> that's a stupid waste of time. Should have been INTS_PER_BLK=8.
> >>>> With INTS_PER_BLK=4, I agree with your values but the problem
> >>>> is still there. I have found what appears to be the problem.
> >>>> The stride arg in the Create_vector method appears to be
> >>>> ignored. It doesn't matter what I set it to, 0 on up to
> >>>> nprocs*blocksize, the block data for each proc is written
> >>>> out contiguously.
> >>>> If I set the view displacement to be myrank*nints,
> >>>> the file always looks like this, without
> >>>> any holes, for any number of blocks and stride I set
> >>>> (nprocs is 2, neg is rank 0, pos is rank 1):
> >>>> 0000000 0 -1 -2 -3
> >>>> 0000020 -4 -5 -6 -7
> >>>> 0000040 -8 -9 -10 -11
> >>>> 0000060 -12 -13 -14 -15
> >>>> 0000100 -16 -17 -18 -19
> >>>> 0000120 -20 -21 -22 -23
> >>>> 0000140 -24 -25 -26 -27
> >>>> 0000160 -28 -29 -30 -31
> >>>> 0000200 0 1 2 3
> >>>> 0000220 4 5 6 7
> >>>> 0000240 8 9 10 11
> >>>> 0000260 12 13 14 15
> >>>> 0000300 16 17 18 19
> >>>> 0000320 20 21 22 23
> >>>> 0000340 24 25 26 27
> >>>> 0000360 28 29 30 31
> >>>> If I set the view displacements to
> >>>> blocksize*sizeof(int)*myrank, the file looks like this,
> >>>> for any stride (nblocks/proc is 2 here):
> >>>> 0000000 0 -1 -2 -3
> >>>> 0000020 -4 -5 -6 -7
> >>>> 0000100 0 1 2 3
> >>>> 0000120 4 5 6 7
> >>>> 0000140 8 9 10 11
> >>>> 0000160 12 13 14 15
> >>>> 0000200 16 17 18 19
> >>>> 0000220 20 21 22 23
> >>>> 0000240 24 25 26 27
> >>>> 0000260 28 29 30 31
> >>>> The further reduced code is appended. As far as I can tell
> >>>> it should produce identical datatypes and views as the program
> >>>> on p. 65 of Using MPI-2. It was my impression that that
> >>>> program was intended to read interleaved data, maybe it's
> >>>> not?
> >>>> Thanks,
> >>>> Russell
> >>>> #include "mpi.h"
> >>>> #include <iostream>
> >>>> using namespace std;
> >>>> struct tester
> >>>> tester()
> >>>> : myrank(MPI::COMM_WORLD.Get_rank()),
> >>>> nprocs(MPI::COMM_WORLD.Get_size()),
> >>>> bufsize(FILESIZE/nprocs), nints(bufsize/sizeof(int)),
> >>>> nblocks(1), blocksize(nints/nblocks),
> >>>> filetype(MPI::INT),
> >>>> //fname("pvfs2:/mnt/pvfs/tst/testfile")
> >>>> fname("/home/rcarter/mpibin/testfile")
> >>>> std::ios::sync_with_stdio(false);
> >>>> filetype.Create_vector(nblocks, blocksize, nprocs
> >> * blocksize);
> >>>> filetype.Commit();
> >>>> obuf = new int[bufsize];
> >>>> ibuf = new int[bufsize];
> >>>> ~tester() {
> >>>> delete[] obuf;
> >>>> delete[] ibuf;
> >>>> void write()
> >>>> for (int i = 0; i < nints; ++i) {
> >>>> if (myrank)
> >>>> obuf[i] = i;
> >>>> else
> >>>> obuf[i] = -i;
> >>>> MPI::File f = open_set_view(MPI_MODE_CREATE |
> >> MPI_MODE_WRONLY);
> >>>> f.Write_all(obuf, nints, MPI_INT, status);
> >>>> f.Close();
> >>>> void read()
> >>>> MPI::File f = open_set_view(MPI_MODE_RDONLY);
> >>>> f.Read_all(ibuf, nints, MPI_INT, status);
> >>>> f.Close();
> >>>> if (obuf[i] != ibuf[i]) {
> >>>> cerr << "myrank, i, obuf[i], ibuf[i]: " <<
> >> myrank << " "
> >>>> << i << " " << obuf[i] << " " <<
> >> ibuf[i] << endl;
> >>>> private:
> >>>> static const int FILESIZE = 256;
> >>>> int myrank, nprocs, bufsize, nints, nblocks,
> >> blocksize, *obuf, *ibuf;
> >>>> MPI::Datatype filetype;
> >>>> string fname;
> >>>> MPI::Status status;
> >>>> MPI::File open_set_view(int mode)
> >>>> MPI::File f = MPI::File::Open(MPI::COMM_WORLD,
> >> fname.c_str(),
> >>>> mode, MPI::INFO_NULL);
> >>>> MPI::Offset disp = blocksize * sizeof(int) * myrank;
> >>>> f.Set_view(disp, MPI_INT, filetype, "native",
> >> MPI_INFO_NULL);
> >>>> return f;
> >>>> int main()
> >>>> cerr << "Starting rwall.\n";
> >>>> try {
> >>>> MPI::Init();
> >>>> tester t;
> >>>> t.write();
> >>>> MPI::COMM_WORLD.Barrier();
> >>>> t.read();
> >>>> MPI::Finalize();
> >>>> } catch (exception &e) {
> >>>> cerr << "\nCaught exception: " << e.what() << endl;
> >>>> return -1;
> >>>> } catch (MPI::Exception& e) {
> >>>> cerr << "\nError:\n" << e.Get_error_string();
> >>>> return -2;
> >>>> cerr << "rwall end.\n";
> >>>> return 0;
> >> Russell L. Carter
> >> Esturion, LLC
> >> 2285 Sandia Drive
> >> Prescott, Arizona 86301
> >> 928 308-4154
> Russell L. Carter
> Esturion, LLC
> 2285 Sandia Drive
> 928 308-4154
