[MPICH] FreeBSD and the ch3:smm channel?
Steve Kargl sgk at troutmask.apl.washington.edu
Wed Jan 31 14:56:03 CST 2007
On Wed, Jan 31, 2007 at 01:34:24PM -0600, Darius Buntinas wrote:
> We're working on a fixing this the right way, but in the mean time, as
> long as you don't need to use --enable-fast, edit the file
> src/mpid/ch3/channels/nemesis/setup_channel.args and remove every thing
> after, and including, the line that starts with "eval" (i.e., the eval
> line and the whole for loop).  Then give configure a try again.
> Let me know if this helps.
That appears to work.  I can build and install mpich2 with
the nemesis device.  Unfortunately, it doesn't appear to
help performance on the SMP systems.
Steve
