[MPICH] FreeBSD and the ch3:smm channel?
Darius Buntinas buntinas at mcs.anl.gov
Wed Jan 31 15:40:25 CST 2007
What kind of latency/bandwidth are you getting, and what kind or machine
are you running on?
-d
On Wed, 31 Jan 2007, Steve Kargl wrote:
> On Wed, Jan 31, 2007 at 01:34:24PM -0600, Darius Buntinas wrote:
>> We're working on a fixing this the right way, but in the mean time, as
>> long as you don't need to use --enable-fast, edit the file
>> src/mpid/ch3/channels/nemesis/setup_channel.args and remove every thing
>> after, and including, the line that starts with "eval" (i.e., the eval
>> line and the whole for loop).  Then give configure a try again.
>> Let me know if this helps.
> That appears to work.  I can build and install mpich2 with
> the nemesis device.  Unfortunately, it doesn't appear to
> help performance on the SMP systems.
