[MPICH] FreeBSD and the ch3:smm channel?
Darius Buntinas
buntinas at mcs.anl.gov
Wed Jan 31 13:34:24 CST 2007
We're working on a fixing this the right way, but in the mean time, as
long as you don't need to use --enable-fast, edit the file
src/mpid/ch3/channels/nemesis/setup_channel.args and remove every thing
after, and including, the line that starts with "eval" (i.e., the eval
line and the whole for loop). Then give configure a try again.
Let me know if this helps.
-d
On Wed, 31 Jan 2007, Steve Kargl wrote:
> On Wed, Jan 31, 2007 at 10:24:36AM -0600, Darius Buntinas wrote:
>> On Tue, 30 Jan 2007, Steve Kargl wrote:
>>> On Tue, Jan 30, 2007 at 06:02:18PM -0600, Rajeev Thakur wrote:
>>>> Can you try the ch3:nemesis channel? That will also do shared memory
>>>> within
>>>> a node and TCP across nodes.
>>> nemesis doesn't pass configure.
>>> checking for CLOCK_REALTIME defined in time.h... yes
>>> sourcing /usr/tmp/mpich2-1.0.5/src/mpid/ch3/setup_device
>>> RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
>>> sourcing /usr/tmp/mpich2-1.0.5/src/mpid/ch3/channels/nemesis/setup_channel
>>> RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
>>> eval: 1: Syntax error: word unexpected (expecting ")")
>>> I spent an hour or so scouring configure scripts to local the
>>> problem, but failed. I guess there is an assumption of bash
>>> for the shell, which I don't use.
>> What's your configure line?
>> -d
> Any of the following generate the above above message
> ./configure --with-device=ch3:nemesis --with-mpe --prefix=/usr/local
> ./configure --with-device=ch3:nemesis --prefix=/usr/local
