[MPICH] FreeBSD and the ch3:smm channel?
Steve Kargl
sgk at troutmask.apl.washington.edu
Wed Jan 31 11:58:08 CST 2007
On Wed, Jan 31, 2007 at 10:24:36AM -0600, Darius Buntinas wrote:
> On Tue, 30 Jan 2007, Steve Kargl wrote:
> >On Tue, Jan 30, 2007 at 06:02:18PM -0600, Rajeev Thakur wrote:
> >>Can you try the ch3:nemesis channel? That will also do shared memory
> >>within
> >>a node and TCP across nodes.
> >nemesis doesn't pass configure.
> >checking for CLOCK_REALTIME defined in time.h... yes
> >sourcing /usr/tmp/mpich2-1.0.5/src/mpid/ch3/setup_device
> >RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
> >sourcing /usr/tmp/mpich2-1.0.5/src/mpid/ch3/channels/nemesis/setup_channel
> >RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
> >eval: 1: Syntax error: word unexpected (expecting ")")
> >I spent an hour or so scouring configure scripts to local the
> >problem, but failed. I guess there is an assumption of bash
> >for the shell, which I don't use.
> What's your configure line?
> -d
Any of the following generate the above above message
./configure --with-device=ch3:nemesis --with-mpe --prefix=/usr/local
./configure --with-device=ch3:nemesis --prefix=/usr/local
Steve
