[MPICH] FreeBSD and the ch3:smm channel?
Darius Buntinas
buntinas at mcs.anl.gov
Wed Jan 31 10:24:36 CST 2007
What's your configure line?
-d
On Tue, 30 Jan 2007, Steve Kargl wrote:
> On Tue, Jan 30, 2007 at 06:02:18PM -0600, Rajeev Thakur wrote:
>> Can you try the ch3:nemesis channel? That will also do shared memory within
>> a node and TCP across nodes.
> nemesis doesn't pass configure.
> checking for CLOCK_REALTIME defined in time.h... yes
> sourcing /usr/tmp/mpich2-1.0.5/src/mpid/ch3/setup_device
> RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
> sourcing /usr/tmp/mpich2-1.0.5/src/mpid/ch3/channels/nemesis/setup_channel
> RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
> eval: 1: Syntax error: word unexpected (expecting ")")
> I spent an hour or so scouring configure scripts to local the
> problem, but failed. I guess there is an assumption of bash
> for the shell, which I don't use.
