[MPICH] FreeBSD and the ch3:smm channel?
Steve Kargl sgk at troutmask.apl.washington.edu
Tue Jan 30 22:20:00 CST 2007
On Tue, Jan 30, 2007 at 06:02:18PM -0600, Rajeev Thakur wrote:
> Can you try the ch3:nemesis channel? That will also do shared memory within
> a node and TCP across nodes.
nemesis doesn't pass configure.
checking for CLOCK_REALTIME defined in time.h... yes
sourcing /usr/tmp/mpich2-1.0.5/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /usr/tmp/mpich2-1.0.5/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
eval: 1: Syntax error: word unexpected (expecting ")")
I spent an hour or so scouring configure scripts to local the
problem, but failed.  I guess there is an assumption of bash
for the shell, which I don't use.
Steve
