[MPICH] mpich 1.2.7 and application profiling freeze
Jan Wagner jwagner at kurp.hut.fi
Wed Jan 31 08:37:13 CST 2007
Haven't yet tried. It's too large a piece of code that is using MPICH-1 to
be migrated so fast...  :-|
So is there some special way to get gnu gcc profiling to work with MPICH-1
dependent code?
thanks,
 - Jan
On Tue, 30 Jan 2007, Rajeev Thakur wrote:
> Is there any reason you need to use MPICH-1? Can you try MPICH2 instead?
> Rajeev
> > -----Original Message-----
> > From: owner-mpich-discuss at mcs.anl.gov
> > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Jan Wagner
> > Sent: Tuesday, January 30, 2007 3:01 AM
> > To: mpich-discuss at mcs.anl.gov
> > Subject: [MPICH] mpich 1.2.7 and application profiling freeze
> > Hi,
> > I'm using mpich 1.2.7b compiled from sources, and I try to run
> > applications over 'mpirun' that have been compiled with the
> > '-pg' flag to
> > enable profiling.
> > The compiler used for mpich and for compiling the application is:
> > [jwagner at ps3-001 ~]$ g++ -v
> > Using built-in specs.
> > Target: ppc64-yellowdog-linux
> > Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
> > --infodir=/usr/share/info --enable-shared --enable-threads=posix
> > --enable-checking=release --with-system-zlib --enable-__cxa_atexit
> > --disable-libunwind-exceptions --enable-libgcj-multifile
> > --enable-languages=c,c++,objc,obj-c++,java,fortran
> > --enable-java-awt=gtk
> > --disable-dssi
> > --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
> > --enable-secureplt --with-long-double-128 --host=ppc64-yellowdog-linux
> > --build=ppc64-yellowdog-linux --target=ppc64-yellowdog-linux
> > --with-cpu=default32
> > Thread model: posix
> > gcc version 4.1.1 20060525 (Yellow Dog 4.1.1-1)
> > When the application is compiled without -pg it works just fine with
> > mpirun.
> > But when the -pg compile and link flag are set, mpirun will simply not
> > progress:
> > running /home/jr/correlator/mpifxcorr-GNU-gprof on 8 LINUX
> > ch_p4 processors
> > Created /home/jr/correlator/PI3664
> > There are no RSH or SSH connection attempts in auth.log.
> > Checking with strace -f, at "stuck" time there are just a lot of
> > [pid  6226] sigreturn()                 = ? (mask now [])
> > [pid  6226] --- SIGPROF (Profiling timer expired) @ 0 (0) ---
> > [pid  6226] sigreturn()                 = ? (mask now [ABRT
> > BUS FPE KILL
> > USR1 SEGV USR2 PIPE TERM STKFLT CONT STOP TSTP TTIN TTOU URG XCPU XFSZ
> > VTALRM PROF WINCH])
> > Any ideas how to get gprof profiling to work?
> > (btw I don't want to profile MPI, or MPI message passing -
> > just profile my
> > application internally when it runs a distributed test case)
> > thanks,
> >  - Jan
