[MPICH] mpich 1.2.7 and application profiling freeze
Rajeev Thakur
thakur at mcs.anl.gov
Wed Jan 31 10:45:45 CST 2007
> So is there some special way to get gnu gcc profiling to work
> with MPICH-1 dependent code?
I don't know.
Rajeev
> -----Original Message-----
> From: Jan Wagner [mailto:jwagner at kurp.hut.fi]
> Sent: Wednesday, January 31, 2007 8:37 AM
> To: Rajeev Thakur
> Cc: mpich-discuss at mcs.anl.gov
> Subject: RE: [MPICH] mpich 1.2.7 and application profiling freeze
> Haven't yet tried. It's too large a piece of code that is
> using MPICH-1 to
> be migrated so fast... :-|
> with MPICH-1
> dependent code?
> thanks,
> - Jan
> On Tue, 30 Jan 2007, Rajeev Thakur wrote:
> > Is there any reason you need to use MPICH-1? Can you try
> MPICH2 instead?
> > Rajeev
> > > From: owner-mpich-discuss at mcs.anl.gov
> > > [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Jan Wagner
> > > Sent: Tuesday, January 30, 2007 3:01 AM
> > > To: mpich-discuss at mcs.anl.gov
> > > Subject: [MPICH] mpich 1.2.7 and application profiling freeze
> > > Hi,
> > > I'm using mpich 1.2.7b compiled from sources, and I try to run
> > > applications over 'mpirun' that have been compiled with the
> > > '-pg' flag to
> > > enable profiling.
> > > The compiler used for mpich and for compiling the application is:
> > > [jwagner at ps3-001 ~]$ g++ -v
> > > Using built-in specs.
> > > Target: ppc64-yellowdog-linux
> > > Configured with: ../configure --prefix=/usr
> --mandir=/usr/share/man
> > > --infodir=/usr/share/info --enable-shared --enable-threads=posix
> > > --enable-checking=release --with-system-zlib --enable-__cxa_atexit
> > > --disable-libunwind-exceptions --enable-libgcj-multifile
> > > --enable-languages=c,c++,objc,obj-c++,java,fortran
> > > --enable-java-awt=gtk
> > > --disable-dssi
> > > --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
> > > --enable-secureplt --with-long-double-128
> --host=ppc64-yellowdog-linux
> > > --build=ppc64-yellowdog-linux --target=ppc64-yellowdog-linux
> > > --with-cpu=default32
> > > Thread model: posix
> > > gcc version 4.1.1 20060525 (Yellow Dog 4.1.1-1)
> > > When the application is compiled without -pg it works
> just fine with
> > > mpirun.
> > > But when the -pg compile and link flag are set, mpirun
> will simply not
> > > progress:
> > > running /home/jr/correlator/mpifxcorr-GNU-gprof on 8 LINUX
> > > ch_p4 processors
> > > Created /home/jr/correlator/PI3664
> > > There are no RSH or SSH connection attempts in auth.log.
> > > Checking with strace -f, at "stuck" time there are just a lot of
> > > [pid 6226] sigreturn() = ? (mask now [])
> > > [pid 6226] --- SIGPROF (Profiling timer expired) @ 0 (0) ---
> > > [pid 6226] sigreturn() = ? (mask now [ABRT
> > > BUS FPE KILL
> > > USR1 SEGV USR2 PIPE TERM STKFLT CONT STOP TSTP TTIN TTOU
> URG XCPU XFSZ
> > > VTALRM PROF WINCH])
> > > Any ideas how to get gprof profiling to work?
> > > (btw I don't want to profile MPI, or MPI message passing -
> > > just profile my
> > > application internally when it runs a distributed test case)
> > > thanks,
> > > - Jan
