[MPICH] mpich 1.2.7 and application profiling freeze
Rajeev Thakur thakur at mcs.anl.gov
Tue Jan 30 12:30:37 CST 2007
Is there any reason you need to use MPICH-1? Can you try MPICH2 instead?
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Jan Wagner
> Sent: Tuesday, January 30, 2007 3:01 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: [MPICH] mpich 1.2.7 and application profiling freeze
> Hi,
> I'm using mpich 1.2.7b compiled from sources, and I try to run
> applications over 'mpirun' that have been compiled with the
> '-pg' flag to
> enable profiling.
> The compiler used for mpich and for compiling the application is:
> [jwagner at ps3-001 ~]$ g++ -v
> Using built-in specs.
> Target: ppc64-yellowdog-linux
> Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
> --infodir=/usr/share/info --enable-shared --enable-threads=posix
> --enable-checking=release --with-system-zlib --enable-__cxa_atexit
> --disable-libunwind-exceptions --enable-libgcj-multifile
> --enable-languages=c,c++,objc,obj-c++,java,fortran
> --enable-java-awt=gtk
> --disable-dssi
> --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
> --enable-secureplt --with-long-double-128 --host=ppc64-yellowdog-linux
> --build=ppc64-yellowdog-linux --target=ppc64-yellowdog-linux
> --with-cpu=default32
> Thread model: posix
> gcc version 4.1.1 20060525 (Yellow Dog 4.1.1-1)
> When the application is compiled without -pg it works just fine with
> mpirun.
> But when the -pg compile and link flag are set, mpirun will simply not
> progress:
> running /home/jr/correlator/mpifxcorr-GNU-gprof on 8 LINUX
> ch_p4 processors
> Created /home/jr/correlator/PI3664
> There are no RSH or SSH connection attempts in auth.log.
> Checking with strace -f, at "stuck" time there are just a lot of
> [pid  6226] sigreturn()                 = ? (mask now [])
> [pid  6226] --- SIGPROF (Profiling timer expired) @ 0 (0) ---
> [pid  6226] sigreturn()                 = ? (mask now [ABRT
> BUS FPE KILL
> USR1 SEGV USR2 PIPE TERM STKFLT CONT STOP TSTP TTIN TTOU URG XCPU XFSZ
> VTALRM PROF WINCH])
> Any ideas how to get gprof profiling to work?
> (btw I don't want to profile MPI, or MPI message passing -
> just profile my
> application internally when it runs a distributed test case)
> thanks,
>  - Jan
