[MPICH] problems with writing in mpi, slaves processes doesnt write
Luiz Mendes luizmendesw at gmail.com
Tue Jan 16 06:54:00 CST 2007
Hi all,
I have two PCS here. One of them, the master node and the another one that
is a slave.
I installed mpich 1.2.7p1 and configured the two machines in Machine.LINUXfile.
Well, but when i test io operations with 2 processes, the slave process
doesnt write. Why?
i have installed mpich 1.2.7p1 on the 2 pcs in the same folder,
/usr/share/MPI-1, and after i export /usr/share/MPI-1 from the master node
to the slave node, mouting it in /usr/share/MPI-1 in slave PC.
What should i do to make it works?
And, do you know something about use pvfs2+mpich 1.2.7p1?
thanks
Luiz Mendes
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20070116/5e9fcf43/attachment.htm>
