[MPICH] WRF and MPICH2
Scott Atchley
atchley at myri.com
Fri Aug 17 15:05:16 CDT 2007
And it runs!
I will patch the WRF clean script to delete this soft-link.
Scott
On Aug 17, 2007, at 3:48 PM, Scott Atchley wrote:
> Hi Rajeev,
> <grins>
> I previously built WRF with mpich-mx. In $WRF/share, there is
> mpif.h which is a soft-link to $MPICH-MX/include/mpif.h.
> Apparently, WRF's ./clean -a does not remove it. I changed it to
> point to MPICH2's mpif.h and I am recompiling.
> Thanks to Rajeev and Brian Dobbins for pointing this out. :-)
> Scott
> On Aug 17, 2007, at 3:11 PM, Rajeev Thakur wrote:
>> Yes this looks like a case where a compiler or mpif.h got used
>> from some
>> other MPI implementation.
>> Rajeev
>>> -----Original Message-----
>>> From: owner-mpich-discuss at mcs.anl.gov
>>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Scott Atchley
>>> Sent: Friday, August 17, 2007 1:11 PM
>>> To: mpich-discuss at mcs.anl.gov
>>> Subject: [MPICH] WRF and MPICH2
>>> Hi all,
>>> I am trying to run WRF2.1 using MPICH2's ch3:ssm over gigabit
>>> Ethernet. When I start the job, I get:
>>> [cli_0]: aborting job:
>>> Fatal error in MPI_Comm_size: Invalid communicator, error stack:
>>> MPI_Comm_size(112): MPI_Comm_size(comm=0x5b,
>>> size=0x7fff18349588) failed
>>> MPI_Comm_size(70).: Invalid communicator
>>> for each process. I have compiled MPICH2 and WRF with PGI 6.2.6 and
>>> 7.0.7 with the same results. If I run it with -gdb, there are no
>>> symbols and I cannot debug. I tried compiling MPICH2 with --enable-
>>> g=all and then running it with -gdb, but it hangs and never gives me
>>> a gdb command line.
>>> Does anyone have experience with this?
>>> Thanks,
>>> Scott
