[MPICH] WRF and MPICH2
Scott Atchley
atchley at myri.com
Fri Aug 17 14:48:09 CDT 2007
Hi Rajeev,
<grins>
I previously built WRF with mpich-mx. In $WRF/share, there is mpif.h
which is a soft-link to $MPICH-MX/include/mpif.h.
Apparently, WRF's ./clean -a does not remove it. I changed it to
point to MPICH2's mpif.h and I am recompiling.
Thanks to Rajeev and Brian Dobbins for pointing this out. :-)
Scott
On Aug 17, 2007, at 3:11 PM, Rajeev Thakur wrote:
> Yes this looks like a case where a compiler or mpif.h got used from
> some
> other MPI implementation.
> Rajeev
>> -----Original Message-----
>> From: owner-mpich-discuss at mcs.anl.gov
>> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Scott Atchley
>> Sent: Friday, August 17, 2007 1:11 PM
>> To: mpich-discuss at mcs.anl.gov
>> Subject: [MPICH] WRF and MPICH2
>> Hi all,
>> I am trying to run WRF2.1 using MPICH2's ch3:ssm over gigabit
>> Ethernet. When I start the job, I get:
>> [cli_0]: aborting job:
>> Fatal error in MPI_Comm_size: Invalid communicator, error stack:
>> MPI_Comm_size(112): MPI_Comm_size(comm=0x5b,
>> size=0x7fff18349588) failed
>> MPI_Comm_size(70).: Invalid communicator
>> for each process. I have compiled MPICH2 and WRF with PGI 6.2.6 and
>> 7.0.7 with the same results. If I run it with -gdb, there are no
>> symbols and I cannot debug. I tried compiling MPICH2 with --enable-
>> g=all and then running it with -gdb, but it hangs and never gives me
>> a gdb command line.
>> Does anyone have experience with this?
>> Thanks,
>> Scott
