[MPICH] Keyboard input with -gdb option?
Ralph Butler rbutler at mtsu.edu
Mon Sep 18 20:44:40 CDT 2006
This does not happen to me.   mpiexec is merely taking stdin.  It
sounds like a terminal
configuration issue.  The cmd "stty -a" can be used to determine the
keystrokes associated
with backspace, del, etc.
--ralph
On MonSep 18, at Mon Sep 18 5:31PM, James Frye wrote:
> Hi,
> I'm trying to use the -gdb option of mpiexec, but am running into a
> rather annoying problem.  It seems that whatever function is used
> to pass keystrokes to the debugger instances must bypass normal
> keyboard handling, because nothing other than the alphanumeric keys
> seem to work.  For instance, if I try to use the backspace key to
> correct a typo, it writes ^H to the screen, and appends a literal
> ^H to the input buffer.  That mean that I essentially have to type
> everything perfectly, or my debugging session crashes.
> Since that sort of manual dexterity isn't my strong suit, I'm
> getting kind of frustrated.  Is there some way to fix this?
> Thanks,
> James
