[MPICH] Forking exisiting mpi processes
James S Perrin james.s.perrin at manchester.ac.uk
Wed Sep 20 06:27:15 CDT 2006
	I'm looking for some details of what can and can't be done if a running mpi
process forks.
	From a simple test program it seems, at least with MPICH, that the child
process inherits the mpi environment and credentials of the parent and can make
MPI calls as if it were the parent process. The child process should simply exit
on completion and only the parent process should call MPI_Finalize. Child to
child communication is best done using a dedicated MPI_Comm, the same as working
with threads. However is thread support actaully required? Should
MPI_thread_init be called?
Regards
James
James S. Perrin,                   | email: james.perrin at manchester.ac.uk
Manchester Visualization Centre,   | www.sve.man.ac.uk/General/Staff/perrin
Kilburn Building, The University,  | tel: +44 161 275 6945
Manchester, England. M13 9PL.      | fax: +44 161 275 6800/6040
"The test of intellect is the refusal to belabour the obvious" -Alfred Bester
