[MPICH] Keyboard input with -gdb option?
    James Frye
    frye at cs.unr.edu
    Mon Sep 18 17:31:22 CDT 2006
I'm trying to use the -gdb option of mpiexec, but am running into a rather
annoying problem.  It seems that whatever function is used to pass
keystrokes to the debugger instances must bypass normal keyboard handling,
because nothing other than the alphanumeric keys seem to work.  For
instance, if I try to use the backspace key to correct a typo, it writes
^H to the screen, and appends a literal ^H to the input buffer.  That mean
that I essentially have to type everything perfectly, or my debugging
session crashes.
Since that sort of manual dexterity isn't my strong suit, I'm getting kind
of frustrated.  Is there some way to fix this?
James
