R: Re: [MPICH] MPI_Probe, MPI_Iprobe MPI_Bcast
Ashley Pittman
ashley at quadrics.com
Mon Sep 18 09:12:51 CDT 2006
On Mon, 2006-09-18 at 15:54 +0200, Thomas Moschny wrote:
> On Monday 18 September 2006 15:33, Ashley Pittman wrote:
> > I don't believe this is technically true if you read the spec carefully.
> > Obviously MPI_Barrier() performs a barrier and any process will block
> > until all other processes have made the same call, it is after all the
> > purpose of the function.
> > MPI_Bcast() on the other hand *doesn't* make any statement about
> > performing a barrier, all it states is that you receive data from the
> > root. There are some implementations that spring to mind (mpich1
> > springs to mind) where the root sends the data onto the network and then
> > returns without waiting for the data to arrive.
> You are right, formally. The standard says, that "Collective routine calls can
> (but are not required to) return as soon as their participation in the
> collective communication is complete."
> However, especially wrt the original question starting this thread,
> the 'advice to users' given a bit later in the standard is of importance to:
> "[...] On the other hand, a correct, portable program must allow for the fact
> that a collective call /may/ be synchronizing. Though one cannot rely on any
> synchronization side-effect, one must program so as to allow it."
Yes, I was thinking of it from the other side of the coin, I once saw a
benchmark for MPI_Bcast() that was getting near infinite bandwidth as
the time was only measured on the root, relying on the behaviour either
way is a bad thing.
> That's what I had in mind here. And for sure it is always an error if one of
> the members of a process group doesn't call MPI_Bcast while all others do.
Indeed, this is quite an important thing to understand if just starting
off with MPI.
Ashley,
