[MPICH] Using MPI_COMM_SPAWN correctly
Hrant P. Hratchian
hhratchi at indiana.edu
Tue Oct 24 23:27:16 CDT 2006
I'm a basic MPI user and I've built a set of code that uses MPI_COMM_SPAWN.
The way that the code runs the master process runs on only 1 process while
the slave processes use n processes.
I have a mpd.hosts file that includes three machines: node_1, node_2, and
node_3. mpdtrace confirms that the loop has been established and runs over
all three machines. To run the code I execute the following on node_1:
mpiexec -n 1 Prog_Master test.in >& test.mpilog &
Prog_Master spawns 4 processes using MPI_COMM_SPAWN. Rather than spreading
the 4 spawned processes across the three machines listed in mpd.hosts (where
the loop is running), all 4 spawned processes run on node_1.
Am I doing something wrong here?
Thanks in advance.
HPH
Hrant P. Hratchian, Ph.D.
E. R. Davidson Fellow
Department of Chemistry
Indiana University
Bloomington, Indiana 47405-7102
812.856.0829
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20061025/be8ac04d/attachment.htm>
