[MPICH] Using MPI_COMM_SPAWN correctly
    Rajeev Thakur
    thakur at mcs.anl.gov
    Wed Oct 25 12:39:01 CDT 2006
Are you using a single MPI_Comm_spawn with maxprocs=4 to spawn the four
process? In that case, I believe they will get spread across the nodes. If
you use four separate MPI_Comm_spawns with maxprocs=1, they will get spawned
on the same node.
Rajeev
  _____
[mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Hrant P. Hratchian
Sent: Tuesday, October 24, 2006 11:27 PM
Subject: [MPICH] Using MPI_COMM_SPAWN correctly
I'm a basic MPI user and I've built a set of code that uses MPI_COMM_SPAWN.
The way that the code runs the master process runs on only 1 process while
the slave processes use n processes.
I have a mpd.hosts file that includes three machines: node_1, node_2, and
node_3.  mpdtrace confirms that the loop has been established and runs over
all three machines.  To run the code I execute the following on node_1:
mpiexec -n 1 Prog_Master test.in >& test.mpilog &
Prog_Master spawns 4 processes using MPI_COMM_SPAWN.  Rather than spreading
the 4 spawned processes across the three machines listed in mpd.hosts (where
the loop is running), all 4 spawned processes run on node_1.
Am I doing something wrong here?
Thanks in advance.
HPH
Hrant P. Hratchian, Ph.D.
E. R. Davidson Fellow
Department of Chemistry
Indiana University
Bloomington, Indiana 47405-7102
812.856.0829
hhratchi at indiana.edu
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20061025/de7a5b6a/attachment.htm>
