[MPICH] MPICH2 ports and firewall issues - limit port range ?
Martin Schwinzerl martin.schwinzerl at stud.uni-graz.at
Wed Jun 14 11:26:59 CDT 2006
Ralph M. Butler wrote:
> Hi Martin:
> The MPICH_PORT_RANGE is the right way to go.  However, you are right
> that mpdcheck does
> not know about the notion of a port range.  So,  I would say if you
> disabled the firewall and gotten
> everything to work, i.e. mpds on multiple hosts, etc.), then you may
> just want to re-enable the firewall,
> set MPICH_PORT_RANGE, and try mpd directly.
> --ralph
Thank you for your quick reply !
One of the problems I have is, that I'm not sure wheter the
MPICH_PORT_RANGE variable is treated
correctly (or better phrased : the way I would expect it), because of
things like the following example :
mas at thph037214:~> export MPICH_PORT_RANGE="8000..9000"
mas at thph037214:~> mpd --echo &
[1] 4986
mas at thph037214:~> 1090
1090
mas at thph037214:~> mpdallexit
[1]+  Done                    mpd --echo
Consequently, the environment variable seems to have no countable effect
on the behaviour of
mpdboot, at least I wasn't able to bring one (quite trivial) ring of two
computers up and
running.
I've also experimented with the --listenport option (and consequently
with the --host and --port options
at a remote machine ) to boot the ring manually. While I was able to
manually boot the ring  (cf below),
and mpdtrace worked like expected, the execution of the example program
cpi (LOCATION_OF_MPICH2/examples/cpi)
via mpiexec resulted in a timeout (the programm worked for the given
setup like a charm, when the firewall was turned of)
Example listing :
Machine A
mas at thph037214:~> mpd --listenport=8100 &
[1] 5220
mas at thph037214:~> mpdtrace
thph037214
thph037217
[1]+  Done                    mpd --listenport=8100
Machine B
mas at thph037217:~> export MPICH_PORT_RANGE="8000..9000"
mas at thph037217:~> mpd --port=8100 --host=thph037214 &
[1] 26597
mas at thph037217:~> mpdallexit
[1]+  Done                    mpd --port=8100 --host=thph037214
Again, I would appreciate any comments or suggestions concerning my problem.
 Best Regards
 Martin Schwinzerl
PS.: As a related question : Is there any documentation available
(besides the user manual and the installation manual),
which I can turn to to learn more about the internals of mpich and/or
the mpi standard ? I feel terrible stranded with my
very limited knowledge at this stage. Thanks in advance !
Martin Schwinzerl
Institute of Physics
University Graz
Austria
http://physik.uni-graz.at/~mas
"Tomorrow is going to be wonderful, because tonight, I do not understand
anything"
Niels Bohr
