[MPICH] MPICH_PORT_RANGE environment variable
Ralph Butler
rbutler at mtsu.edu
Thu Jul 6 13:12:20 CDT 2006
Hi Martin:
The code I ran is available via the release candidate at:
ftp://ftp.mcs.anl.gov/pub/mpi/mpich2-1.0.4-rc1.tar.gz
mpd uses MPIEXEC_PORT_RANGE if available, else uses
MPICH_PORT_RANGE if it is available.
--ralph
On WedJul 5, at Wed Jul 5 8:48AM, Martin Schwinzerl wrote:
> Dear all,
> I've still problems / open questions regarding the usage of the
> MPICH_PORT_RANGE variable
> and would be very thankful if somebody here could again try to help
> me :
> As discussed earlier (http://www-unix.mcs.anl.gov/web-mail-archive/
> lists/mpich-discuss/2006/06/msg00026.html),
> I've so far not succeeded to limit the port range of mpd et al by
> storing the desired port range into an env. variable
> (cf example below).
> my open questions :
> Since Ralph Butler was able to use the mpd sucessfully with the
> MPICH_PORT_RANGE variable,
> I would like to ask, if this was achieved using the developer
> version from CVS, or the "public" version 1.0.3 ?
> Is the MPICH_PORT_RANGE variable sensitive to other enviroment
> variables (MPIEXEC_PORTRANGE ?)
> or other enviromental influences, so that there might be an
> interference ?
> example :
> mas at thph037214:~> export MPICH_PORT_RANGE=8100:8200
> mas at thph037214:~> echo $MPICH_PORT_RANGE
> 8100:8200
> mas at thph037214:~> mpd --echo &
> [1] 31058
> mas at thph037214:~> 1047
> 1047
> mas at thph037214:~> mpdallexit
> [1]+ Done mpd --echo
> System information :
> mpich2-1.0.3 , Compiled with Intel's icc 9.0 or gcc 4.x (aboves
> example
> is reproducible with both of them), compiled with f77,f90 and c++
> bindings,
> python 2.4.1, network consists at the moment for testing purposes
> of two
> OpenSuSE 10.1 powered 32 Bit Pentium4 class computers.
> Many thanks in advance !
> Best regards
> Martin
