[MPICH] Unable to execute process on different machines (ERROR : bash: line 1: orted: command not found)
    Rusty Lusk
    lusk at mcs.anl.gov
    Thu Dec 21 06:11:14 CST 2006
You should follow the instructions for using mpdcheck in the User's
Guide, before using mpdboot.
Rusty Lusk
On Dec 21, 2006, at 5:13 PMDecember, Pravin_Kumar at jubilantbiosys.com
wrote:
> Hello Sir
> I am trying to execute the process on two machines for which i am
> using
> mpiexec here when i give the machine name to execute the process using
> option -machinefile or -hostfile or just using -h <machine name> i get
> following the error :
> [server:02392] ERROR: A daemon on node samiron failed to start as
> expected.
> [server:02392] ERROR: There may be more information available from
> [server:02392] ERROR: the remote shell (see above).
> [server:02392] ERROR: The daemon exited unexpectedly with status 127.
> The machines where i want to execute the process can ssh without
> password.
> and  these machines are having the identical copy of mpd.host and
> ..mpd.conf.  When I use the command 'mpdboot -f mdp.hosts' and then
> 'mpdtrace -l ' I get only the current machine listing and not the
> listing
> for other machine mentioned in 'mpd.hosts'. I have compiled and
> installed
> the same version of mpich2 on both machines.
> Kindly help
> With best regards
> Pravinkumar
> This Message and any attachment (the "message") is intended solely
> for the addressees and is confidential.
> If you receive this message in error, please delete it and
> immediately notify the sender.
> Any use not in accord with its purpose, any dissemination or
> disclosure, either whole or partial,
> is prohibited except formal approval. The internet can not
> guarantee the integrity of this message.
> Jubilant Organosys Ltd. (and its subsidiaries) shall (will) not
> therefore be liable for the message if modified.
